Home > For Sale & Wanted > [Wanted] WANTED L320 05-13 dog guard loweer brackets |
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 |
Just found your post, I’ve just done the same thing, bought a used one with the arms on the top, but no floor brackets..
Sat Jul 06 2019 12:38pm |
AW8 Member Since: 26 Mar 2018 Location: Sussex Posts: 60 |
Glad I am not alone....Hopefully my wanted advert might cause some to check their vehicles to see if they have spare floor brackets they might be prepared to part with.
Wed Jul 10 2019 1:44pm |
I haven’t even been that professional! I am using cable ties at the moment. A complete fitting kit is £100... Current: 2010 RRS 3.6 TDV8 HSE
Wed Jul 10 2019 2:38pm |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
to be honest it stays in fine without the lower brackets 2012 SDV6 HSE (technically its hers)
Thu Jul 11 2019 8:24am |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 |
As Duc said, perfectly secure without any brackets. |
Thu Jul 11 2019 7:40pm |
Excuse me please if I’m being a mong!! How does it stay in place without the lower brackets? There is nothing else to support it unless I’m missing more than I thought. Current: 2010 RRS 3.6 TDV8 HSE
Thu Jul 11 2019 7:49pm |
I have the top brackets. There are tabs that locate against the plastic either side of bootspace to stop it falling back ...it's a snug fit. Not likely to tilt baxk due to angle albeit I have used some old karabiners to restrict lower edge bottom bits popping back.
Thu Jul 11 2019 10:18pm |
I’m laughing cos I didn’t even notice them just placed it in the boot and cabled tied it in place via the head rests and load rings.. shows you observant I am. Current: 2010 RRS 3.6 TDV8 HSE
Fri Jul 12 2019 7:20am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
I’ve got them fitted. Do you want me to take measurements?
Fri Jul 12 2019 9:37am |
so its actually held in place by the tabs that go behind the seats when the seats are upright - the upper arms stop the guard top rotating forward and the frame stops it rotating backward - I think the only thing those brackets really do is stop the dog guard moving when the seats are down but the full height guard effectively stops you using the load area with the seats down anyway. 2012 SDV6 HSE (technically its hers) 2000 D2 TD5 - definitely mine 2005 D3 V8 Metalian Camper trailer for adventures |
Fri Jul 12 2019 11:03am |
Thanks for the replies gents, I’ve just been out and had a look. It doesn’t fit properly as it’s not the right one..
Fri Jul 12 2019 11:38am |
Freelander 2
Fri Jul 12 2019 12:16pm |
Thanks for the offer but as you say it’s a bit far! I just checked and you are right it’s Freelander 2. I get rid in time, meanwhile I’ve got my eye on another one, this time I’ll buy the right one.. Current: 2010 RRS 3.6 TDV8 HSE
Fri Jul 12 2019 2:31pm |
Steve, Thanks for replying. I would be most grateful if you could take various measurements and update me...Either on this thread or by PM. Genuinely appreciated |
Fri Jul 12 2019 10:48pm |
