![]() | Home > General > Towing electrics |
you have a late model, which I believe doesn't have fuses in the rear for the towbar.
Akitamum Member Since: 15 Jun 2019 Location: Cheshire Posts: 17 ![]() ![]() |
Thanks Andy,unfortunately all fuses are fine |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Have you tested the RRS with another caravan or trailer, or tested the caravan with another car? Is it definately the RRS with the problem and not the caravan wiring?
Caravan was tested with another vehicle on Sunday and all was fine so definitely the RRS,we've had it to an auto electrician today explained the problem and asked to change to 13 pin as well,took it up to the caravan this evening and still the same |
Sorry side lights don't come on either car or caravan when connected |
If an auto electrician changed from the 12N&12S to 13pin just today then I would presume (hope) he tested the socket with a tester of some sort?
All seems a genuine plug and play kit, we had the side panel and left rear light out the other day.
Are you handy with a voltmeter as it'd be worthwhile working through the pins looking for voltages as per the diagram. 13MY Range Rover Sport Autobiography SDV6 - mine
Well check the side light wire with a test lamp in the rear left quarter
We haven't done on this one as yet,though did on the 7 pin and 5 & 7 had nothing,we had no idea where to go from there hence why taking it in today, really seems like they have just swopped the socket and not checked anything. |
Any help? I think these are the plugs behind L/H boot panel, I assume there is no issue with the vehicle side lights with the caravan dis-connected.
I’m still saying it’s a fuse by glovebox. |
If the side lights are working on the vehicle that only really leaves fuse No.27 Trailer Side Lamps, if not then it has to be 24 & 25.
Blown fuses would be a good result, but why would the RRS side lights work ok without trailer connected, but not when connected? That's the bit that's confusing me, it often can be a short, but if it's fused and no blown fuses....... 13MY Range Rover Sport Autobiography SDV6 - mine
