Home > General > Towing electrics
Akitamum
Thank you All for all the help and suggestions.
Even though we checked the fuses last night and none had actually blown,a fuse was the culprit,not sure exactly which one though imagine fuse 27.
So happy days and all now sorted.
Thank you once again Very Happy
Post #583827 Thu Jul 11 2019 4:38pm
Akitamum
One last question or 3 😁 do the towing electrics need to be coded? And how will we know if they have/haven't already been done? Also is it essential to have them done if it is needed?
Post #583831 Thu Jul 11 2019 6:12pm
I guess the main thing is if the reverse sensors and disabled when a trailer is connected.
Otherwise don’t worry
Post #583833 Thu Jul 11 2019 6:19pm
Akitamum
Fantastic! Thanks Andy
Post #583838 Thu Jul 11 2019 7:26pm
Brit Plumber
And the suspension changes to. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #583844 Thu Jul 11 2019 10:16pm
Akitamum
Thanks Brit Plumber,when we attached the electrics sensors seem to of been switched off so hopefully suspension will be fine also,will find out tomorrow.
Post #583876 Fri Jul 12 2019 1:23pm
