Home > Detailing & Car Cleaning > Weekend car wash - how to save the battery? |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
I made that mistake a few weeks ago,, never gave it a though, had the doors open etc and was playing with seat positions and when I went to start it the battery was proper flat. Next time I might consider disconnecting the battery! 2010 RRS, TDV8
Sat Jun 29 2019 11:16am |
AW8 Member Since: 26 Mar 2018 Location: Sussex Posts: 60 |
OP.....No idea what yer or type of car you have (you can add it in signature if so motivated).
Sat Jun 29 2019 2:26pm |
SVR fan Member Since: 03 Mar 2019 Location: Surrey Posts: 28 |
Thanks very much - signature updated
Sun Jun 30 2019 4:07pm |
Not related to car clean time but bet thing is to use a reconditioning charger...of more benefit in colder weather when battery can suffer more but every 4 months won't hurt.
Tue Jul 09 2019 9:14am |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
If you have tow electrics, you could do as many D4 owners do, and charge the battery thro' the aux. socket. Lleave it on while polishing and for a few hours after, and you'll be okay.
Tue Jul 09 2019 10:04am |
Just to add the one I linked to is under £20.....although I referenced ctek it's an ultimate speed ..identical ro mine which I got from lidl (not in stock
Tue Jul 09 2019 1:04pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
The Ctek mx10 can provide 12V via tow socket adaptor so stops battery draining.
Tue Jul 09 2019 3:44pm |
Thanks all for your responses. Trickle charge is difficult as I’m in a flat and getting a power supply to the car is very tricky and not something I feel I should have to do to wash the car?
Sun Jul 21 2019 9:27am |
Needing a power supply just to wash a car is clearly over the top here. If the car drains it's battery while the doors are open for a few minutes to wash the door jams, then something is wrong.
Sun Jul 21 2019 9:46am |
