![]() | Home > Detailing & Car Cleaning > Weekend car wash - how to save the battery? |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 950 ![]() ![]() ![]() |
I made that mistake a few weeks ago,, never gave it a though, had the doors open etc and was playing with seat positions and when I went to start it the battery was proper flat. Next time I might consider disconnecting the battery! 2010 RRS, TDV8
AW8 Member Since: 26 Mar 2018 Location: Sussex Posts: 60 ![]() ![]() |
OP.....No idea what yer or type of car you have (you can add it in signature if so motivated).
SVR fan Member Since: 03 Mar 2019 Location: Surrey Posts: 28 ![]() ![]() |
Thanks very much - signature updated |
Not related to car clean time but bet thing is to use a reconditioning charger...of more benefit in colder weather when battery can suffer more but every 4 months won't hurt.
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
If you have tow electrics, you could do as many D4 owners do, and charge the battery thro' the aux. socket. Lleave it on while polishing and for a few hours after, and you'll be okay.
Just to add the one I linked to is under £20.....although I referenced ctek it's an ultimate speed ..identical ro mine which I got from lidl (not in stock
The Ctek mx10 can provide 12V via tow socket adaptor so stops battery draining.
Thanks all for your responses. Trickle charge is difficult as I’m in a flat and getting a power supply to the car is very tricky and not something I feel I should have to do to wash the car?
Needing a power supply just to wash a car is clearly over the top here. If the car drains it's battery while the doors are open for a few minutes to wash the door jams, then something is wrong.
