Home > General > Which RRS: 2012 high mileage or 2009 low mileage? |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 |
Big changes between the two, lights to tail gate. interiror changes two versions of infotainment further on and a big change to the gearbox - 6 to 8 speed which in some theories gets rid of the propensity to blow up engines and snap cranks 2012 SDV6 HSE (technically its hers)
Tue Jul 02 2019 11:38am |
SvenGB Member Since: 02 Jul 2019 Location: Surrey Posts: 12 |
Thanks, that’s really helpful.
Wed Jul 03 2019 7:54am |
If pre facelift it's totally different, if you're looking at a facelift car the differences are not so apparent but more under the surface. For example on our my13 car the satnav is updated very differently from an my10 facelift.
Wed Jul 03 2019 8:19am |
How come? Were the V8 more reliable than the V6? I'd prefer the economy over the acceleration personally, but if having a chain instead of a timing belt adds more reliability then maybe thats the way to go? |
Wed Jul 03 2019 8:40am |
"Reliable" is an interesting definition and so is economy.
Wed Jul 03 2019 10:43am |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
Interesting take on things Duc750.
Wed Jul 03 2019 3:24pm |
To be honest I've always "idled down" every turbo car I've ever had. I've also thoroughly enjoyed exercising the sequential turbos on twin turbo cars on a regular basis
Wed Jul 03 2019 3:41pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8976 |
The 8-speed doesn't change the propensity of 3.0V6 crank failures. They fail at any age on either gearbox.
Wed Jul 03 2019 4:22pm |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
That was part of my logic when buying the (at that point) cheapest 2010 TDV8 on Autotrader (from a dealer) - £3k less than the nearest comparison gives me plenty of wiggle room to do the things I expect to have to do at 100k (suspension bushes are a given, the dealer had to drop £1000 on both EGR valves including fitting under warranty, etc).. and then cross my fingers and hope |
Wed Jul 03 2019 4:41pm |
To the OP you're getting some good responses here including some from owners that have had both in your original query I've not had both ends of the spectrum. As a result I can probably not add much further other than to say I stand by the research I did in my purchase decision most of which I have shared here.
Wed Jul 03 2019 5:21pm |
I was starting to think that everyone here was from Lincolnshire, reading other threads.. apparently all the Northampton folks came to this thread.. |
Wed Jul 03 2019 7:04pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
I don't know what your thoughts are on this;
Wed Jul 03 2019 7:25pm |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
Go for a TDV8
Wed Jul 03 2019 9:47pm |
I bought my TDV8 in Leicestershire and had it serviced , initially, by an Oxfordshire LR dealership before moving to an Oxfordshire indy. I bought my SDV6 from a forum member in Hampshire (is that right Rob?) before again having it serviced by the same Oxfordshire Indy. Both vehicles lived/live with me in Northamptonshire. So that's four counties covered by two vehicles. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Jul 03 2019 10:44pm |
