Home > Maintenance & Modifications > Side steps running boards replacement recommendations please |
PompeyDave Member Since: 08 Jul 2018 Location: Portsmouth Posts: 64 |
No one have any experience with these at all please? |
Tue Jul 02 2019 11:45am |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2793 |
I have replaced a few sets from Sports I have purchased that was battered & worse for wear . It was only ever the steps I replaced - the brackets are hidden & didn't seem as rough as the steps themselves. If I remember rightly I never paid moref than £120 & that was for the sets with pre cut plastic sills. The 3 sets was all off fleabay - I have checked my purchase history but it doesn't go back that far
Tue Jul 02 2019 12:00pm |
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 |
I noticed my running boards were getting worse for wear also - so I've ordered a set of ebay for around £110. I'll let you know how I get on - probably be end of July before I get a chance to fit them though. |
Tue Jul 02 2019 12:20pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
I have these ones which are £99.99 with free delivery from TurboRevs:
Tue Jul 02 2019 1:10pm |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
When you decide, buy a 5ltr can on Waxoyl and paint it on the underside, (incl. brackets) with a brush as you fit them. check once a year and they'll last. 2011 MY D4 HSE
Wed Jul 03 2019 6:27am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
An hour ago I just got out of the car and as I placed my 104kg on it the silver trim popped off at the leading edge. I tried to pop it back in but it wouldn’t stay. Put it on off road height to have a peek and there is surface corrosion but the first 2 heads of the lugs that keep the trim in the step have gone. So I’ve pressed it against the step drilled a hole at the forward most end just behind the front wheel and bolted it in. You can’t obviously see the bolt and it will keep it going for a bit.
Wed Jul 03 2019 2:38pm |
