Home > Maintenance & Modifications > Hydrographics Carbon Fibre Dipped Engine Cover
Evo5man
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
I have been thinking for some time about trying out some RRS modifications using carbon fibre hydrographics dipping technology.
The plastic windscreen scuttle cover, the plastic A pillar covers and plastic D pillar covers are all suffering quite badly from bleaching due to sunlight exposure and are very expensive to replace. I have tried various products on them to get them back to black but they only last a few weeks at best. I did think about having them painted matt black but then came up with the idea of carbon fibre dipping.
Rather than start with the external trims, I decided to have the engine cover carbon dipped as an experiment. I know that this will not be to everyone's taste but I am pleased with the result. Let me know what you think, but be kind with your comments!!
Post #583237 Sat Jun 29 2019 10:25am
gogsy1956
I'm quite impressed to be honest,, just been having a look online and the possibilities seem to be endless,,, even possible to do wheels. Just wondering what the costs are and how hard wearing is it. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #583238 Sat Jun 29 2019 10:53am
Evo5man
Hi Gogsy1956,
Following on from the carbon dipping they applied a 2K clear lacquer (not sure how many coats) which is supposed to give better scratch resistance. Regarding durability, I guess time will tell. I did wonder about the effect of heat under the bonnet but was assured that the hydrographic system will not be affected. Not sure how the A pillar trims would hold up with the same treatment to stone chips and bugs? I guess no better or worse than if you have them painted matt black?
Costs seem to vary a lot between different companies, I was quoted between £100 and £300 by 4 companies to have the engine cover done.
Post #583241 Sat Jun 29 2019 11:09am
gogsy1956
Not exactly cheap then,,,, hate to think what wheels would cost 2010 RRS, TDV8
22" overfinch
Post #583243 Sat Jun 29 2019 11:32am
Evo5man
I would definitely be worried about durability of this system on wheels and what do you do if you kerb one of them? Probably would need to have the whole wheel stripped and re-dipped at great expense.
I think that this system is best suited to small interior plastic trim parts that look a bit boring or have been scratches. The cost for smaller parts seems more reasonable, the engine cover needed several coats of primer and a lot of prep. I would expect the A and D pillar trims to be more reasonable.
Post #583244 Sat Jun 29 2019 11:40am
Autobiography1969
I also am impressed with the finish but not the cost,
as you said internals would be a good choice, if you
take good care of the things done they should last
quite some time, another option for pillars would be
Vinyl wrapping them in either Matte or Gloss..
Yet another idea for some changes later on.. Thumbs Up ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #583256 Sat Jun 29 2019 2:17pm
Damon White
United Kingdom 2012 Range Rover Sport SDV6 HSE Sumatra Black
Looks great. What was the cost?
Thanks
Damon
Post #583259 Sat Jun 29 2019 2:21pm
Evo5man
If you shop around you should be able to get the engine cover done for about £125. I purchased a used engine cover to have carbon dipped so I can retain the existing engine cover. I can then swap out engine covers when the car goes in for a service to avoid any possible damage during the service.
There was a lot of prep work to the engine cover but other plastic trim parts should be a lot cheaper.
Post #583279 Sat Jun 29 2019 6:31pm
DEVON
Oh I really like it Thumbs Up
Could I ask what prep work is involved ?
Post #583280 Sat Jun 29 2019 7:15pm
Evo5man
I am no expert on the prep work but here is what the paint shop told me:
1. Remove the rubber locating tabs, oil filler tube rubber and sound proofing.
2. Degrease plastic.
3. Rub down plastic to provide a key for the primer.
4. Primer 1st coat.
5. Rub down primer.
6. Primer 2nd coat.
7. Rub down primer.
8. Float carbon fibre film on water tank.
9. Spray activating agent on carbon fibre film.
10. Dip cover in water tank with carbon fibre film floating on it
11. Leave to dry
12. Spray cover with 2K clear lacquer.
13. Bake cover in spray booth to harden lacquer.
14. Polish final finish.
15. Refit rubber fixings and sound proofing
And that is all there is to it! Confused
Post #583281 Sat Jun 29 2019 8:02pm
riverblanche
another Thumbs Up for the look
but
Shocked for the cost.
then again we did wrap all our kitchen cupboards for about £25 Whistle Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #583282 Sat Jun 29 2019 8:04pm
DEVON
[quote="Evo5man"]I am no expert on the prep work but here is what the paint shop told me:
Thanks for your reply
Will be looking into this Thumbs Up
Post #583287 Sat Jun 29 2019 8:53pm
