Home > General > Bolt sheared on rear hub
Silverman
United Kingdom 2006 Range Rover Sport 4.4 V8 HST Java Black
Hi guys
I had a rear wheel work loose yesterday as I was driving, luckily I caught it just in time.
One of the bolts has sheered off and typically my mot is booked in for Monday morning!
Do I need to get a complete hub (part ruc500120) or can the hub be removed and a new bolt installed from behind? If the latter I have a chance to get done before the mot.....
Thanks
Post #583235 Sat Jun 29 2019 9:26am
gogsy1956
You can certainly buy the studs,,,,,, I was actually surprised how easy they come out. I accidentally hit one with a hammer ( not a Rangerover though) and out it popped, managed to put it back using the wheel nut to pull it back in so you may not even have to take the hub off. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #583240 Sat Jun 29 2019 11:08am
Disco_Mikey
A wheel stud has sheared?
Post #583248 Sat Jun 29 2019 12:57pm
Brit Plumber
I guess the wheel being loose caused the stud to shear, cos if not I’d be concerned for the other 4. Thinking about it, I’d be concerned the damage has been done and you may need a new hub to be sure the other studs haven’t developed any stress’s. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #583250 Sat Jun 29 2019 1:11pm
Silverman
Yes that’s exactly what happened. I heard a knocking and when I inspected the studs weren’t tight.
Thanks gogsy, I’ll try this. If there’s access to get to it from behind it sounds easy Smile
I tried to buy a stud today but nothing local so I’ll have to order one
I assume it’s 14mm 1.5mm pitch. Does anyone know the correct length?
Thanks
Post #583257 Sat Jun 29 2019 2:18pm
Tyrefitter
& check the wheel because the holes could now be elongated & if they are & you put the wheel back on they will loosen again Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #583261 Sat Jun 29 2019 3:02pm
Disco_Mikey
No way to fit a rear stud without pressing the hub out of the bearing
I've tried Neutral
Post #583264 Sat Jun 29 2019 3:10pm
Brit Plumber
In that case I’d put a new hub, bearing and probably a brake backing plate on at the same time. 2019 5.0 SC SVA (Current)
Post #583276 Sat Jun 29 2019 5:25pm
Brit Plumber
Sorry, double post. 2019 5.0 SC SVA (Current)
Post #583277 Sat Jun 29 2019 5:25pm
