![]() | Home > Maintenance & Modifications > crankshaft diy removal |
tony waterman Member Since: 23 Jun 2019 Location: benwick march cambs Posts: 13 ![]() ![]() |
sorry made a mistake i am referring to the crankshaft not the camshaft |
well you need to disconnect it from the gearbox.
excuse my ignorance but if it is just the crankshaft that has gone and there is no other sign of damage how does it scrap the engine. |
I think you would be lucky if that was the case |
It warps the block... |
ok thank for the replies looks like its a replacement engine then. |
There’s some photos on here or Disco 4 site from a independent showing a section of engine block sheared off inside after a crank shaft fail. 2019 5.0 SC SVA (Current)
thanks i will have a look, tbh i was hoping it was just a case of the shells slipping as this is a known fault, at some stage i will get underneath and take the sump off and have a look and you never know i might be lucky. |
Always worth a look mate, I would take it apart out of interest alone. 2019 5.0 SC SVA (Current)
They have an upper and lower sump.
As Mike says, the blocks can warp on these engines when the cranks snap. There have been numerous reports of snapped cranks being replaced along with new bearings then shortly after - bang, it goes again.
you would recommend oval auto's wouldn't you ? |
Yes, I used Oval Autos and they were great. The engine is very smooth running. Kev
i think its a trip to halfords for a manual first, i have no choice but to try and do this myself, i was 2 days away from px this car for a 2016 hse when this happened so i still went ahead with the purchase and i only had it 2 weeks when it was stolen, it was recovered but was a write off due to a high speed police chase and i got left 12k out of pocket because of no gap insurance which i had never heard of so at the moment i am still paying for a car i dont have and now my only option is to try and get this one back on the road for as little money as possible. |
