Home > Maintenance & Modifications > Steering Has Become Heavy
skid1963
Hi guys
Over the last week i have noticed the steering has become very heavy especially when cold, and it will not self centre without requiring some input from me to return the steering wheel to "straight ahead" position at low speed when turning out of junctions etc.
The car was just MOT'd this morning and i mentioned it to the tester (local indy) when i took it in, car passed with no advisories (good news), i said did you have a good look at front bushes, power steering, rack etc?
He said the bushes are fine but he found a small oil leak but could not pinpoint where it was coming from, said all reservoirs where fine on their levels, said it could be the rack or the power steering pump.
Is the pump a common problem on these? What about the rack?
I was playing around with the suspension heights last weekend but not sure that is relevant?
Any thoughts on this please guys? 2015 L494 SDV6 3.0 HSE Loire Blue
2006 L320 4.2 Supercharged
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #582845 Sat Jun 22 2019 9:31am
Autobiography1969
Tyre Pressures all correct?? ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #582847 Sat Jun 22 2019 11:28am
skid1963
Yup, tyre pressures within 1lb of recommended, i have also noticed a bit of creaking when on full lock manoevering, thought that indicates bushes but not according to tester.
I am a bit stumped
Edit....should point out they are standard tyres/wheels 275/40/20 2015 L494 SDV6 3.0 HSE Loire Blue
Post #582848 Sat Jun 22 2019 11:38am
Oldandconfused
There is a UJ in the steering column which can stiffen up causing heavy steering and lack of self-centering.
https://www.advancedfactors.co.uk/lr071146...3638-p.asp
Some have given it a good soaking with a lubricant (grease/silicone spray) and while that's a temporary fix, it will give you an idea if that's the culprit. I'm sure there was a thread about a steering speed sensor that could cause similar symptoms, but can't find it. Looks like it needs jacking up and having a good look, as the oil you mention may be coming from the rack causing your problem.
Post #582849 Sat Jun 22 2019 12:07pm
skid1963
Thanks for the suggestions oldandconfused, hope it's not the rack as can't see that being cheap, will try lubing the UJ first 2015 L494 SDV6 3.0 HSE Loire Blue
Post #582850 Sat Jun 22 2019 12:11pm
Brit Plumber
Are you thinking of the SASM? Steering angle sensor module? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #582876 Sun Jun 23 2019 9:20am
Re: Steering Has Become Heavy
Did you put the height back to standard? Camber changes with ride height as does, I think, caster (the wheelbase changes slightly as the suspension height changes - you can see this as the wheels rotate ever do slightly as the height changes from access to road to off road). Toe stays the same.
Changing camber and caster will alter the steering weight and self-centering effect.
If you have set a new ride height, then an alignment is required. Camber, caster and toe are all shown on the Hunter laser alignment system. 2012 SDV6 - it's missing a couple of cylinders
Post #582881 Sun Jun 23 2019 10:28am
skid1963
@rrstdv8 Yup, ride height set to normal, not set to a different height, will give it another play with the height settings and see if it helps the car settle back to where it should be regarding the steering problem, although i can't see it helping as i have done 2 50 mile runs since i noticed the problem
As suggested previously, i think it needs to go up on a ramp to investigate minor oil leak as it could be the rack, bearing in mind i'm getting the creaking on full lock 2015 L494 SDV6 3.0 HSE Loire Blue
Post #582884 Sun Jun 23 2019 10:40am
Oldandconfused
Are you thinking of the SASM? Steering angle sensor module?[/quote]
I'm sure it was something about the speed sensitive steering and the sensor that determines the level of assistance, hence it being heavy. Does the SASM do that? As I say, it was a thread I saw but didn't pay too much attention to because I haven't had that problem, yet.
Post #582915 Sun Jun 23 2019 9:21pm
