![]() | Home > Maintenance & Modifications > Steering Has Become Heavy |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 473 ![]() ![]() |
Tyre Pressures all correct?? ===========================================
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 213 ![]() ![]() ![]() |
Yup, tyre pressures within 1lb of recommended, i have also noticed a bit of creaking when on full lock manoevering, thought that indicates bushes but not according to tester.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
There is a UJ in the steering column which can stiffen up causing heavy steering and lack of self-centering.
Thanks for the suggestions oldandconfused, hope it's not the rack as can't see that being cheap, will try lubing the UJ first 2015 L494 SDV6 3.0 HSE Loire Blue
Are you thinking of the SASM? Steering angle sensor module? 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9025 ![]() ![]() ![]() |
Did you put the height back to standard? Camber changes with ride height as does, I think, caster (the wheelbase changes slightly as the suspension height changes - you can see this as the wheels rotate ever do slightly as the height changes from access to road to off road). Toe stays the same. Changing camber and caster will alter the steering weight and self-centering effect. If you have set a new ride height, then an alignment is required. Camber, caster and toe are all shown on the Hunter laser alignment system. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
@rrstdv8 Yup, ride height set to normal, not set to a different height, will give it another play with the height settings and see if it helps the car settle back to where it should be regarding the steering problem, although i can't see it helping as i have done 2 50 mile runs since i noticed the problem
Are you thinking of the SASM? Steering angle sensor module?[/quote]
