Home > Maintenance & Modifications > Brembro break disks 380mm |
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 |
So this is where I might be getting confused I need to know the model number of the 2012 Supercharged RRS? Mine is the SDV6 which is a L322 model? What’s the model of the S/C because I’m upgrading to those brakes. Cheers Laurence. |
Thu Jun 13 2019 9:29am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5028 |
If you have a Sport it is a L320 irrespective of which engine is fitted, a L322 is a fullfat
Thu Jun 13 2019 10:21am |
My Original Land Rover discs have the word brembo dot stamped on them so if you see the original brembo discs cheaper than at LR, buy them. 2019 5.0 SC SVA (Current)
Thu Jun 13 2019 3:25pm |
Don't think this is a bad price for genuine L/R discs, not sure my original discs had Brembo stamped on them, the genuine replacements from L/R certainly didn't.
Thu Jun 13 2019 9:57pm |
The brembo marking was very small and in dot markings so difficult to see and I didn’t see it until after I painted them. I still have a spare in the garage (they were V cheap for genuine LR from a dealer). 2019 5.0 SC SVA (Current)
Thu Jun 13 2019 10:30pm |
May have been there then in that case but never noticed, but to be fair wasn't actualy looking, the original were pretty rusty so probably wouldn't have seen it anyway.
Thu Jun 13 2019 10:37pm |
Thanks guys L320 is where I was going wrong! I’m struggling with the finding the larger Brembro calliper 20” Supercharged set I think? Also to upgrade my 4 pot callipers to the larger 6 pot do I need dust covers and different wires? Not knowing a great deal about all this wish there was a garage I could drive in get them to Dom the work and drive out!! Life is never that easy... Cheers Laurence. |
Fri Jun 14 2019 4:28am |
Quick look at a parts list, apart from the obvious discs, calipers, pads and pad fitting kit about the only other thing you need is the wear sensor wire, the backplates appear to be same part number. The large carrier mounting bolts on the original ones can be used to mount the Brembo caliper as they are also appear to be the same number. When I replaced my discs I did use new bolts as they are not very expensive and torqued up pretty tight 275 Nm. if I remember right.
Fri Jun 14 2019 5:21am |
Thanks Col....
Fri Jun 14 2019 5:44am |
Some of the part numbers may have been superseded by now, but all the same on the 2010-2013 Sport.
Fri Jun 14 2019 5:58am |
I had to take my rear discs off to lube the EPB so I got some photos of the Brembo marked disc along with the LR part details.
Sun Jul 14 2019 8:48am |
Strange as the S/C never had Brembo brakes on the rear from the factory.
Sun Jul 14 2019 9:01am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Could they be for a 322, in the 1st photo you can see LAND ROVER AH322. I have no knowledge just an observation
Sun Jul 14 2019 9:42am |
There’s a good chance they share the same brakes. I should do a EPC check on the engineering number and see if they are common to both models.
Sun Jul 14 2019 9:47am |
