Home > Maintenance & Modifications > Brembro break disks 380mm
Brit Plumber
Stevepd wrote:
Could they be for a 322, in the 1st photo you can see LAND ROVER AH322. I have no knowledge just an observation Thumbs Up
Steve.
I think the 322 is coincidence as AH is year 2010 (the A) the 32 is used on lots of models and not entirely sure what it signifies. The next number starting in 2? Is the call out number. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #583973 Sun Jul 14 2019 10:51am
According to L/R's Microcat parts system The S/C version of the L322 and the L320 do not share the same rear disc's. The L320 S/C rear disc LR016192 only fits the L320 no other models though, that's not to so they won't fit other models. A brembo aftermarket disc number is 09.A774.11
I hope it is a optical illusion but some wheel studs appear to be bent in the pictures. Smile
Post #583974 Sun Jul 14 2019 11:00am
N60613
Bosnia Herzegovina
Buster007,
I have recently changed my front disks (l322 4.4 TDV8) "Brembo" for "Textar Pro +" and I am very happy with them.
By the way, Brembo do not manufacture discs or pads only calipers. discs and pads are made by somebody else and branded as Brembo.
 RR 2012 4.4 TDV8
Post #584000 Mon Jul 15 2019 8:31am
