Home > Wheels & Tyres > Tpms
Dougall2001
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
Tpms
My 22”s are in getting powder coated just now but just got a call from the shop saying the first Tpms has snapped during removal on the first wheel.
By the sound of things it looks like all 4 have been overtightened and worst case all 4 might snap when the try to remove them. Hopefully not tho but time will tell.
Anybody got any advise? Also has anybody used the pre programmed aftermarket ones? Seen a few sets on EBay.
Land Rover quoting £90 a Wheel not programmed.
Thanks 2014 RR Sport Autobiography - Best looking sofa on wheels I’ve ever owned
Post #581120 Mon May 20 2019 4:56pm
Tyrefitter
You can get them off eBay but make sure the numbers match yours as I’m sure their is 2 different numbers,I once got a set off eBay for a spare set when I was running 2 sets of alloys & the first set didn’t work properly but the seller changed them & ive now got them as spares as I got rid of my other alloys. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #581122 Mon May 20 2019 5:26pm
Dougall2001
Thanks mate, il wait and see what the guys come back to me with once they try and remove the rest.
Any tips for removing them?
Cheers 2014 RR Sport Autobiography - Best looking sofa on wheels I’ve ever owned
Post #581123 Mon May 20 2019 5:39pm
Tyrefitter
Basically you just unscrew them,when refitting you only need to get a 12mm socket & tighten by hand holding the socket don’t let them over tighten them as they only need to be 4nm,if over tightened they can damage the rubber seal & they could leak.They do corrode over time & snap when removed as they are only alloy. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #581124 Mon May 20 2019 5:45pm
Brit Plumber
Fit 4 new Stems now rather than a few hundred miles down the road. They aren’t expensive unless the 2014 Sport has a different system. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #581126 Mon May 20 2019 6:42pm
If your VIN No.is after EA319923 provided your actual sensor is o.k you can buy a stem repair kit LR043162 from L/R for about £30.00 suitible to do all Five wheels.
Changeable
Non Changeable
Post #581131 Mon May 20 2019 10:25pm
Brit Plumber
Even the non changeable ones are available on eBay. I have 4 here, you undo that little screw. The whole system is still crap though, from materials to function. The old ford system is better and uses the same components! 2019 5.0 SC SVA (Current)
Post #581132 Tue May 21 2019 5:33am
Brit Plumber
https://www.ebay.co.uk/itm/4-x-Tyre-Pressu...Swi0RbJPRW 2019 5.0 SC SVA (Current)
Post #581133 Tue May 21 2019 5:36am
Tyrefitter
& another word of advice,Don’t use the metal dust cap as they have a habit of reacting with the alloy/copper valve & then after time you cannot get them off without damaging the valve & cutting them off.I get at least 2 customers a week especially with mercs & beemers as they fit them standard. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #581134 Tue May 21 2019 5:47am
Brit Plumber
Had the same with plastic caps. The proper ones are the grey ones with a sealing lip on the inside at the bottom to prevent water entering the shrader valve. The standard black plastic ones just don’t cut it but are better than the steel logo ones. 2019 5.0 SC SVA (Current)
Post #581135 Tue May 21 2019 6:27am
Genuine L/R plastic one's, only £20.00 a set, mines lasted 5 years so far. Laughing
Post #581136 Tue May 21 2019 6:34am
Brit Plumber
Oh, now I like those.
Got a pt number Col? 2019 5.0 SC SVA (Current)
Post #581137 Tue May 21 2019 8:15am
Still the same number I think, have to admit surprised nobody nicked mine by now. Rolling with laughter
Post #581138 Tue May 21 2019 8:27am
