![]() | Home > Maintenance & Modifications > Front brake slider pins |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
This might help.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
Thanks for that Col, looks like they just pull out |
I use a set of thin long nose grips to hold the slider from spinning.
I think Iv'e got it now, if a 17mm spanner won't fit on the inner nut, use mole grips on it, not on the slider pin gator. |
Don’t put the grips on the gaiters as they could split,between the gaiter & the calliper their is enough to get a 17mm spanner or some thin grips like I use. Andy.
Thanks for that, I will have a look Sunday or next week, weather permitting. |
