Home > Maintenance & Modifications > Checking oil level MY11 5.0SC
J.Prezes
Poland 2011 Range Rover Sport Supercharged Autobiography Santorini Black
So after a drive home today I've checked the oil level and I have to admit it's low (and no I didn't look for a dip stick). While reading service manual, about electronic dip stick, I've stumbled across a "special", extra informative procedure. Annoyingly it doesn't work, which would be nice for tomorrows refill. So could you for the sake of general knowlegde go and check if you'll manage to open oil menu in service mode Wink
Post #580947 Thu May 16 2019 9:12pm
Autobiography1969
Just to let you know if you haven't read about it yet..
From the manual;
The actual reading on the dash is only an indication of the top 1.5 litres,
there is 5.9 litres (3.0 Diesel) in total so when this is indicating as on the low level,
the max you should need to top up with is 1.5 litres..
Unless it tells you how much to put in,
I would just top it up in by 0.5 litre and then increments of 0.5 litres and see where its goes to..
I run mine between OK and full..never over fill it..I am sure you know that.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #580948 Thu May 16 2019 9:36pm
Never tried that before, but then never needed to, works o.k. on mine though provided bonnet's open.
Post #580952 Fri May 17 2019 5:53am
J.Prezes
Thanks for the clarification and the last bit I know Thumbs Up
Post #580963 Fri May 17 2019 10:18am
