Home > Maintenance & Modifications > Handbrake stuck on |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 |
Not sure on yours being the rotary gear select,,,, the cup holders in the centre console don't come out by any chance ??? 2010 RRS, TDV8
Sat May 11 2019 2:49pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5002 |
Have a Search in YouTube and see if u can find a vid that matches your interior
Sat May 11 2019 3:20pm |
I’m sure it’s under the cup holder behind the gear knob. Andy.
Sat May 11 2019 3:24pm |
I have the same 2012my with rotary gear selector. On your 2012 if you look in the centre console there are two removeable cup holders. Take them out- can be an effort. Access flap will then be visible. Open. The release mechanism can require a hefty yank mind. |
Sun May 12 2019 9:32am |
imccarrison Member Since: 15 Sep 2018 Location: NEWTOWNARDS Posts: 9 |
Thanks for all the help.
Mon May 13 2019 12:47pm |
Won't hurt to put up with it,,, but get it repaired ASAP, I think you were reasonably lucky getting the emergency release to operate,,, not always guaranteed!. Hopefully it can be cleaned up and readjusted. 2010 RRS, TDV8
Mon May 13 2019 1:59pm |
Well you got it done but the easier way is under the cupholder... Maybe best if you pop in your local indy specialist, epb issues are not unusual and they should be able to diagnose quickly. |
Tue May 14 2019 6:52am |
With the 12MY it’s not that easy to get to the release tab through the cup holders, especially if the cable is tight. Best thing to do is get the Screw Driver out of the boot kit, pop the CD slot cover using the flat blade in the bottom and levering up gently (plastic lever is best but the Screw Driver works in an emergency), remove the 2 Philips screws. Then pull the back of the whole console up (it’s on lots of clips) which can take a good tug. The wiring is long enough by design so that you can rotate it up at the back to remove it and then flip it over and rest on the passenger seat. You then have loads of room to get to the cable tab and get the jack handle onto it with out fear of trashing anything.
Tue May 14 2019 10:31am |
Thanks very much for all the help and replies
Tue May 14 2019 11:02am |
I had no problem via cup holder route. Dismantling the centre console seems a bit extreme. |
Tue May 14 2019 11:59am |
There wasn’t a hope in hell of getting to mine through the cup holder. I followed directions and videos and found nothing. When I took the console out I could see why, it’s located under the EPB switch. Further digging on the internet revealed many more 2012 owners in the same boat. 2019 5.0 SC SVA (Current)
Tue May 14 2019 12:05pm |
We clearly have had different experiences but the cupholder route should be tried first and probably works for the majority with no problem at all and they ate understandably not posting about it. It is a lot less involved. Stuck at the side of the road would be no place to take out the console as was my experience. For most if you can't do the cupholder route you need to call recovery or get your indy involved. |
Tue May 14 2019 12:27pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5027 |
Seem to be a lot of varying opinions how best to do this, but the cup holder is removed on L/H/D vehicles to release it according to L/R workshop manual, but not having had to do it wouldn't really know for sure.
Tue May 14 2019 12:38pm |
Tue May 14 2019 12:43pm |
