Home > Maintenance & Modifications > Lumpy on start-up |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Buster - your not on your own
Mon Mar 07 2016 6:00pm |
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 |
Thanks peachy Cheers Laurence. |
Mon Mar 07 2016 6:19pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
If it's just with the cold weather and first thing I would think glow plugs are playing up. The sooner they are checked/changed the better. 2008 G4 RRSport TDV8 current
Mon Mar 07 2016 6:47pm |
Yes will drop it in as it's still under warranty so the fault is registered with them before the warranty ends Cheers Laurence. |
Mon Mar 07 2016 9:10pm |
Brianx5 Member Since: 30 Jan 2013 Location: AYRSHIRE Posts: 36 |
Good luck with your dealer finding the fault as I have similar problem and was advised to let it develope. |
Tue Mar 08 2016 11:12am |
Ned Member Since: 25 Jul 2015 Location: London Posts: 100 |
Yer my as starting doing it as well, lumpy on start up cold mornings for about 5 seconds my12 rrs. Sounds like a ken a common issue. |
Tue Mar 08 2016 10:49pm |
ross24061986 Member Since: 28 May 2016 Location: United Kingdom Posts: 9 |
if i start the car from cold all is fine until...
Wed May 08 2019 10:17pm |
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 |
Mine is the same but only when it's a little bit colder in the morning and FBH fires itself up. Only lasts 2-3 seconds and just feels like it's running uneven then clears.
Thu May 09 2019 6:19am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Don’t disregard a dodgy injector. If you can get codes read or live values taken, especially with smokey start up.
Thu May 09 2019 7:40am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Lumpy running/injector problem, begs the question, what impact does this have on snapped cranks In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Thu May 09 2019 8:32am |
This is what Kev (knwatkins) said to me after his recent failure. Injectors may have played a part.....
Thu May 09 2019 10:23am |
