![]() | Home > Maintenance & Modifications > Correct Battery for 2013 RRS1 Supercharged |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
Tayna batteries have good reviews and may well give a forum discount.
I fitted a Yuasa 5020 to my SC, it’s longer by 40mm at 393mm but it fits tightly (I think the Diesel uses the same size), spec below.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
That battery should be fine, same spec. as I fitted on mine however I did fit a Varta G14 AGM.
With regards to changing the battery, unlock the car, open the bonnet and leave it for 10 minutes before disconnecting the old battery. This will give the car plenty of time to power everything down. If you pull power before it’s in stand by, it could/can do funny things. 2019 5.0 SC SVA (Current)
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
Thank you for the help so far. How do I know if I need a 'wet' or 'AGM' as the Tanya website shows both lists? B_T_S There is no replacement for displacement - W O Bentley MY2013 5.0 Supercharged HSE L320 |
You don't specifically need a AGM that was just my personal choice, a wet battery was standard fitment and quite adequate.
