![]() | Home > In Car Electronics > Sat nav update advice |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
Just turned on the ignition and left the car without the key, it soon turned everything off. don't want this to happen mid update, and not sure if the system will keep itself awake. So I will have to see how long it will stay awake with the key in. MY12 RRS HSE
Just an update,
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
leave the usb stick in and drive normally...if you stop ,the update will pause until you get going again .... |
I'm not sure it does, there are warnings not to turn off the ignition. Apparently it stuffs the satnav and phone.
The entertainment system is designed to Shutt off after xx minutes (can’t remember the exact length of time). It is also designed to enter low power mode when the engine is not running. 2019 5.0 SC SVA (Current)
Cheers lads
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
You are lucky having a USB stick driven system.
there isnt one...
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 ![]() ![]() |
Where did you buy the update from and how much was it as thinking about doing my 2012 sport.
Pm sent, they are classed as 2018/2019 MY12 RRS HSE
RJM16 Member Since: 11 Nov 2016 Location: Worcestershire Posts: 29 ![]() ![]() ![]() |
Got my USB from the HERE website and after it being replaced because it froze, the car is without sat nav, and telephone.
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Last September I was advised the newest maps get released in May, although not usually sold via Landrover until September October time. So might be worth holding on a couple of weeks if you can, to get the 2019/20 map. 13MY Range Rover Sport Autobiography SDV6 - mine
After 2hours 50minutes the update finally completed. I kept it running for the full duration to ensure there were no errors.
