![]() | Home > Technical > 2010 RRS Windscreen Wiper (arm) issue |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Will ask the obvious, is the securing nut tight (18Nm.)?
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 ![]() ![]() ![]() |
A fair question, it's as tight as I can make it but rusty as anything so I didn't want to use too much force! |
Possibly damaged the splines beyond use so it may well be a new arm and maybe pivot if it’s available as a separate part. 2019 5.0 SC SVA (Current)
Yeah, might find it's worn away inside the arm especially if it's been slightly in the past and the retaining nut's bottoming out. Spindle/shaft not available separate, new linkage £140.00 from L/R even the arm's stupid money at £40.00 from them, think I might look on fleabay first.
That sounds like a sensible course of action, any idea on the part numbers I need to look for.
I think the arm is DKB500060PMD but may have been superceded by now, linkage was DLS500030 now LR038347 will double check numbers later.
