Home > General > Active Dampers? |
Is this not part of the dynamic setup using the rotary knob upto 2012 and switchpack 12 on? 2019 5.0 SC SVA (Current)
Fri May 03 2019 9:50am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Adaptive Dynamic struts have 2 small wires coming out the middle of the strut, right at the top |
Fri May 03 2019 2:25pm |
Is it not easier to look for the hydraulic oil top up cap near the radiator? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri May 03 2019 2:45pm |
Different system Tim |
Fri May 03 2019 3:30pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
If you've got the dynamic programme on Terrain Response (the double-S to the left of the normal setting on the dial/switch) then you have adaptive dampers. 2012 SDV6 - it's missing a couple of cylinders
Fri May 03 2019 3:39pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
That's great, thanks guys. I've just nipped out to the car and I can confirm that there is no 'SS' to the left of the normal setting on the terrain response ie. I have standard dampers.
Fri May 03 2019 5:07pm |
Sorry i’m Getting out of touch after almost a year of not owning one...... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Fri May 03 2019 7:42pm |
I probably didn't help the case by saying that I have active roll control in my original post. I just wasn't sure that if I had ARC, this may have meant that I automatically had the active dampers. Now I know that this is definitely not the case Kev
Fri May 03 2019 7:50pm |
It would be worth checking the top of a damper too, just to be absolutely sure, if you're planning on buying replacements. Any wires going means you do have active dampers fitted. No wires (just the air pipe) means you don't. 2012 SDV6 - it's missing a couple of cylinders
Sat May 04 2019 10:07am |
Thanks guys, I just checked the top of them and there is only the airline there and no wiring Kev
Thu May 09 2019 10:27am |
