Home > In Car Electronics > Bluetooth Not fitted to 2010 HSE?
derekmines
So I was trying to pair my phone with my "new" 2010 RRS this morning and have failed miserably.
When I press the phone button I get a message on the screen saying "phone not fitted" and neither of my handsets find anything when scanning for Bluetooth (I read that pairing needs to be done from the phone not the car) but I can't do that if the phone can't find the car!!
Is it possible that there was no Bluetooth fitted in 2010 or has my module gone bad? how do I find out?
Post #580104 Thu May 02 2019 8:41am
Brit Plumber
I’ve a feeling the 10MY has a Bluetooth module whereas the 12 MY has it built into the CD/Nav unit. Can you PM over your VIN and I’ll see what’s in the As Built CCF. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #580109 Thu May 02 2019 9:07am
geoffsnook
Derek see if you can do a hard reset take both terminals off the battery and put them togrther and hold them togerther for about 15 seconds i think it is abviously away from terminals but should reset the ecu's Thumbs Up
Post #580139 Thu May 02 2019 6:40pm
geoffsnook
The moduals on early ones are in the offside rear wheel arch in the boot if you have one which i would have thought you did Thumbs Up
Post #580140 Thu May 02 2019 6:42pm
riverblanche
can confirm our ex 2010 had it
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #580144 Thu May 02 2019 7:44pm
Godders
Mine is an early MY 2010 and that has it. Never argue with stupid people, they will drag you down to their level and then beat you with experience.
Post #580148 Thu May 02 2019 8:06pm
knwatkins
Mine too. I thought it was standard. Kev
Post #580149 Thu May 02 2019 8:13pm
Brit Plumber
Not standard but fitted to 98% so as good as. 2019 5.0 SC SVA (Current)
Post #580153 Thu May 02 2019 9:34pm
derekmines
Sadly I appear to be in the 2%.... removing the little panel in the boot shows me only one module.... the keyless entry one according to a check of the part # on it.
Is it a simple plug-and-play retrofit?
Post #580155 Thu May 02 2019 9:55pm
Brit Plumber
That’s V odd seeing as the As Built CCF for your VIN shows it as fitted. 2019 5.0 SC SVA (Current)
Post #580159 Thu May 02 2019 11:04pm
Brit Plumber
Phone module
Keyless entry module
Post #580160 Thu May 02 2019 11:23pm
Brit Plumber
Guess what?
The phone module was superceded by AH42-10F845-AA which is.....the central locking module aka, keyless entry. So you do have it.
Post #580161 Thu May 02 2019 11:28pm
derekmines
Interesting....
So I just need to figure out why it's not functional.
I shall try the hard reset mentioned earlier and see where that gets me!
Post #580165 Thu May 02 2019 11:56pm
Brit Plumber
What phone is it? There is a list of compatible phones somewhere. 2019 5.0 SC SVA (Current)
Post #580171 Fri May 03 2019 8:52am
derekmines
I've tried it with an iPhone 6S and a Samsung J3
The Samsung did find a Bluetooth source but when I tried to connect to it it immediately said "could not connect due to incorrect PIN" (Despite there being no option to enter a PIN)
Post #580176 Fri May 03 2019 10:04am
