![]() | Home > In Car Electronics > Bluetooth Not fitted to 2010 HSE? |
I’ve a feeling the 10MY has a Bluetooth module whereas the 12 MY has it built into the CD/Nav unit. Can you PM over your VIN and I’ll see what’s in the As Built CCF. 2019 5.0 SC SVA (Current)
Derek see if you can do a hard reset take both terminals off the battery and put them togrther and hold them togerther for about 15 seconds i think it is abviously away from terminals but should reset the ecu's |
The moduals on early ones are in the offside rear wheel arch in the boot if you have one which i would have thought you did |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
Mine is an early MY 2010 and that has it. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Mine too. I thought it was standard. Kev
Not standard but fitted to 98% so as good as. 2019 5.0 SC SVA (Current)
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 ![]() ![]() ![]() |
Sadly I appear to be in the 2%.... removing the little panel in the boot shows me only one module.... the keyless entry one according to a check of the part # on it.
That’s V odd seeing as the As Built CCF for your VIN shows it as fitted. 2019 5.0 SC SVA (Current)
Phone module
Guess what?
Interesting....
What phone is it? There is a list of compatible phones somewhere. 2019 5.0 SC SVA (Current)
I've tried it with an iPhone 6S and a Samsung J3
