Home > Technical > First Issue With My RRS |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
Buy a new battery before you do anything else. Pointless messing with IID if you don’t have a decent battery. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Sun Apr 28 2019 12:13am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
Personally as suggested I would wack a new battery on it and go from there, if it's the original battery it's done pretty well, with the electrics on these being a bit temperamental for the sake of around £100.00 not worth messing about with. The TPMS on mine occasionally does things like that but it seems to be affected by the ambient temperature, mind you the systems pretty useless anyway.
Sun Apr 28 2019 1:14am |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 470 |
Thanks guys,
Sun Apr 28 2019 10:19am |
I cannot believe it,
Sun Apr 28 2019 2:28pm |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
Or charge the current battery, and get a volt meter on it to check running and loaded voltages.
Sun Apr 28 2019 5:32pm |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 200 |
My original MY2012 battery gave up a few weeks back and just prior was kicking up errors, I cleared them then the battery died in my drive. Europarts to the rescue on a Sunday afternoon! 2018 Telsa MS
Sun Apr 28 2019 5:41pm |
That does it then I will have the new one fitted tomorrow after work..
Sun Apr 28 2019 6:02pm |
I bought a Bosch AGM 3yr warranty and 50% discount that weekend! 2018 Telsa MS
Sun Apr 28 2019 6:08pm |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
Did a new battery cure your issues, I have just had the same experience and codes, although no TPMS fitted so none of those.
Mon Aug 16 2021 3:20pm |
Did a new battery cure your issues, I have just had the same experience and most of your codes, although no TPMS fitted so none of those.
Mon Aug 16 2021 3:21pm |
