![]() | Home > General > Suspension issue with codes. Electrical or compressor? |
Silverman Member Since: 25 Apr 2019 Location: London Posts: 30 ![]() ![]() ![]() |
Hi Andy
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Hi Silverman,
Have you checked the large fuse under the bonnet.
No I didn’t check a large fuse. In my manual all I could find related was 2 small fuses under bonnet and one below glove box. They were all fine. If you could tell me where this is it seems the next thing to check
picture in post above and words updated
Potential good news. That large yellow fuse has blown!
I think they are called J fuses. Also used on Jap cars.
Hi Silverman,
Ok cool. I’ll do a check on the wiring first before I change fuse.
have a check under the car first.
No sunroof.
Nothing suspect on the wires what I could see.
No, relay isn't suspect.
these 3 items could be used to make a tester
