Home > Technical > Strange Keyless Entry Problems
derekmines
So a week into ownership and I have a strange problem.... at first I thought it was me, but a little testing seems not.
I walk to the car, place my hand on the drivers door handle and I can hear the relays work, indicators flash and all the doors unlock as they should..... except the drivers door itself, it seems that no matter what I do that door stays locked unless i reach in from the rear and operate the handle, at that point it open fine, no need to press another button or anything.
Any ideas?
Post #579639 Thu Apr 25 2019 8:01pm
knwatkins
It sounds like the motor in the latch (the larger one of the two). You can either replace the whole latch itself or try and clean the inside of the motor.
Here is a YouTube video on how to remove the latch from the door on a Disco and it's pretty much the same on the RRS...
&t=151s
Here is a guide on how to clean the larger motor within the latch itself....
https://www.disco3.co.uk/forum/door-lock-m...termittent
PS. you'll need a bit of patience removing/reinstalling the latch in the door. Kev
Post #579642 Thu Apr 25 2019 9:14pm
derekmines
Thanks for the info, thankfully it seems like a fairly cheap part even if it does need replacement!
Post #579644 Thu Apr 25 2019 9:19pm
knwatkins
Make sure you get a keyless latch if you are going to change the complete unit Wink
I recently bought one for my rear door from a breakers on eBay - £20 posted. Kev
Post #579645 Thu Apr 25 2019 9:27pm
