![]() | Home > Technical > Strange Keyless Entry Problems |
It sounds like the motor in the latch (the larger one of the two). You can either replace the whole latch itself or try and clean the inside of the motor.
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 ![]() ![]() ![]() |
Thanks for the info, thankfully it seems like a fairly cheap part even if it does need replacement! |
Make sure you get a keyless latch if you are going to change the complete unit |
