![]() | Home > Technical > Hesitation when revving |
Sounds like a sticking turbo actuator though would expect to see engine system fault on the mess centre. Get the codes read see if anything logged 2008 G4 RRSport TDV8 current
Bfeakes Member Since: 08 Dec 2018 Location: Norfolk Posts: 6 ![]() ![]() ![]() |
I’ve put my code reader on and it’s showing no codes at all. It feels the same as when my egr valves went but it’s onlt happened after I changed the top water connector. |
Just read your original post again it would not be the actuator half asleep when I read the post |
No it was working fine before I started just a small water leak from top connector. Just gone back over what I done as I must be something I mucked up. I’ve noticed on the throttle body connector that a rubber ring is perished. Now this to me would mean more air getting into the engine thus mucking up the air / fuel ratio? Sorry to be a pain.
I’ve seen them like that before but carnt see it causing the hesitation as you described it, though it won’t hurt to clean it up and maybe replace the O ring if damaged 2008 G4 RRSport TDV8 current
