Home > General > Hdc fault,suspension lowered,transmission fault, enginefault
absin19
Ok here goes
I have a Range Rover sport 3.6 tdv8
When driving along and also stationary I get the hdc fault, transmission fault, suspension lowered, engine fault
The cluster will then light up loke a Christmas tree with all the lights flashing including the hazards with the speedo and fuel gauge needles jumping around erratically.
I have change the battery, brake light switch and was recommend to have the cluster rebuilt but I’m still having the same issues. Now the auto electrician that carried out the work stated that the errors would occur and the voltage wouldn’t drop or spike so he doesn’t think it’s the alternator.
It failed mot last week due to fluid leek from the anti roll bar at rear. I’ve since been told that the drop links are also shot. Mechanic reckons this could be the cause of the faults but I’m not so sure.
The errors codes always come up the same with intermittent fault of loss of communication for hdc etc
Any help would be appreciated as my next port of call will be a can of petrol and box of matches
Post #579405 Mon Apr 22 2019 9:56am
geoffsnook
What are the codes would be the first port of call we would need to know before everyone started throwing senario's at ypu in response Thumbs Up
Post #579407 Mon Apr 22 2019 11:04am
absin19
U0416-94/temporary
U0132-87/intermittent
U0159-87/intermittent
U0416-87/temporary
Post #579408 Mon Apr 22 2019 11:25am
geoffsnook
There only lack of comms could be anything like a loose cable a faulty switch or a spike in the alternator causing these what code reader was it a Land Rover specific or a general reaver Thumbs Up
Post #579409 Mon Apr 22 2019 12:02pm
absin19
I’ve had three different brake switches in the car
The bulbs have been the same since I bought it a year ago
And they are all working fine as only mot problem was the leaking anti roll bar
It was a Foxwell nt520 reader with Land Rover software
Where are the grounding points located so I can check them?
The auto electrician checked in beside ecu etc and all wiring was fine
Post #579411 Mon Apr 22 2019 12:08pm
geoffsnook
There are various points all over as the hoc uses the brakes as well it could be in the connectors to the terrain respond the hand brake circuit if o were you I would go a search for your problem on here you may get a better idea or try to get the codes read with an IDD tool or similar Thumbs Up
Post #579413 Mon Apr 22 2019 12:30pm
Mgtow127@gmail.com
From what you’ve commented, I can confirm your vehicle is working as expected.
Post #579415 Mon Apr 22 2019 2:27pm
Tim in Scotland
Absin19, sounds like you should contact member Disco-Mikey ( http://www.rrsport.co.uk/forum/member-disco_mikey.html) who is a Land Rover indie and extremely knowledgable about Disco3,4 and RRS - he’s not too far from you in Dundee or you could find his profile and phone him 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #579416 Mon Apr 22 2019 2:37pm
Rolling Eyes 2012 SDV6 - it's missing a couple of cylinders
Post #579427 Mon Apr 22 2019 4:47pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Don't feed the troll. He should stick to ex army skoda's.
Post #579429 Mon Apr 22 2019 4:54pm
knwatkins
Rolling with laughter Kev
Post #579430 Mon Apr 22 2019 5:23pm
geoffsnook
He's hanging around this troll must be waiting for his skoda to be fixed Rolling with laughter Rolling with laughter
Post #579432 Mon Apr 22 2019 5:45pm
Brit Plumber
As it’s an easy check, if you have a sunroof, check the passenger carpet and surrounding areas for damp. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #579451 Tue Apr 23 2019 7:32am
absin19
I don’t have a sun roof and the floor is bone dry
Post #579452 Tue Apr 23 2019 7:36am
Brit Plumber
Thumbs Up 2019 5.0 SC SVA (Current)
Post #579453 Tue Apr 23 2019 7:39am
