![]() | Home > General > Hdc fault,suspension lowered,transmission fault, enginefault |
What are the codes would be the first port of call we would need to know before everyone started throwing senario's at ypu in response |
absin19 Member Since: 22 Mar 2019 Location: Dunfermline Posts: 4 ![]() ![]() ![]() |
U0416-94/temporary
There only lack of comms could be anything like a loose cable a faulty switch or a spike in the alternator causing these what code reader was it a Land Rover specific or a general reaver |
I’ve had three different brake switches in the car
There are various points all over as the hoc uses the brakes as well it could be in the connectors to the terrain respond the hand brake circuit if o were you I would go a search for your problem on here you may get a better idea or try to get the codes read with an IDD tool or similar |
Mgtow127@gmail.com Member Since: 06 Apr 2019 Location: London Posts: 66 ![]() ![]() |
From what you’ve commented, I can confirm your vehicle is working as expected. |
Absin19, sounds like you should contact member Disco-Mikey ( http://www.rrsport.co.uk/forum/member-disco_mikey.html) who is a Land Rover indie and extremely knowledgable about Disco3,4 and RRS - he’s not too far from you in Dundee or you could find his profile and phone him 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9031 ![]() ![]() ![]() |
![]() 2008 TDV8 - it was a labour of love and is much missed |
Don't feed the troll. He should stick to ex army skoda's. |
He's hanging around this troll must be waiting for his skoda to be fixed |
As it’s an easy check, if you have a sunroof, check the passenger carpet and surrounding areas for damp. 2019 5.0 SC SVA (Current)
I don’t have a sun roof and the floor is bone dry |
