Home > Technical > Engine fail 2012 sport,2015 rrs sport engine fit?oil pump?
Bardley
Ask on the D4 forum. You'll find there are a few that will likely know the answer. 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #579304 Sat Apr 20 2019 4:05am
Sudds91
United Kingdom 2012 Range Rover Sport SDV6 HSE Maya Gold
Cheers all,
It’s definitely a solenoid to regulate the oil flow, have just bought a pump and gaskets to swap it over, spoke to green ovel Landy specialists know a lad there he said you need to swap it.
Thanks for replies. 2012 3.0 RRS SDV6 (Currenrly dead)
2007 4.2 Supercharged RRS (Daily)
2003 Ford Focus RS MK1 (Pride and Joy)
Post #579314 Sat Apr 20 2019 8:48am
Sudds91
Right, now to the next problem, the water pump on the new engine is electric, sticks out 10mm more than the other on the pully so mechanic is worried about it throwing the belt off, tried to swap with the original however the block is different, the flange is a lot bigger on the block so the pump will not seal, anyone know if there are any other pumps available that will fit? Maybe off a jag? Cheers 2012 3.0 RRS SDV6 (Currenrly dead)
Post #579475 Tue Apr 23 2019 4:01pm
OvalAutos
What you have there is a EURO 6 engine. You need to leave the original pump on the engine as the block is completely different and has an extra oil gallery hole behind the pump. An earlier pump won't cover the hole and it will pee out oil.
The extra part is a solenoid, primarily for STOP/START loading, but also emissions regulation.
Aside from the extra oil hole, there is also a hole through to the water jacket in the block. This is part of the water cooling system for the primary turbo. There is also a hole on the N/S head where the old knock sensors used to be on earlier engines that is also open to the coolant gallery.
Oh, and the EGR system is completely different Neutral
I hate to say it, but its the same old crankshaft. Joe
Post #579673 Fri Apr 26 2019 1:10pm
Sudds91
Thanks for the info, when we got the water pump problem I just went and bought an engine from a 2011 car, thought that would be better than messing with the other one after checking it’s a 2018 engine with only 17k so I’m just going to put that for sale rather than mess with a perfectly fine engine. So if anyone knows anyone for it? Thanks 2012 3.0 RRS SDV6 (Currenrly dead)
Post #580044 Wed May 01 2019 7:00am
knwatkins
I think you've chosen a more sensible path. Much less hassle. Kev
Post #580061 Wed May 01 2019 12:37pm
Sudds91
Just another 3k on another engine Shocked lol 2012 3.0 RRS SDV6 (Currenrly dead)
Post #580065 Wed May 01 2019 2:00pm
