Home > Maintenance & Modifications > MY10 RRS New Battery advice |
Go for the best you can fit in the tray. I’ve fitted one rated for the Diesals. Yuasa YBX5020 110Ah, 900A. The original was a 90Ah, 850A Land Rover Varta which equates to the Yuasa YBX5019. The bigger battery was 1 inch longer so was a tight fit but it went in.
Wed Apr 03 2019 12:06pm |
GSJ Member Since: 08 Dec 2016 Location: Cardiff Posts: 36 |
Hey Brit Plumber,
Wed Apr 03 2019 12:12pm |
The car configuration file. It lists all the options on the car that need activation to work amongst other things. I believe the car needs to know what battery is fitted so it can charge it in the appropriate manner. 2019 5.0 SC SVA (Current)
Wed Apr 03 2019 1:31pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
Could never work out which to set mine to when upgraded the battery as the particular/size rating was not mentioned in the CCF so left it as was and have had no issues, there is some setting I remember which should be reset so the car knows it has had new battery which relates to the battery monitoring system on the facelift variant if I remember correctly. Although told car works it out for it's self over time don't know if that is correct though, was told that by a Indi.
Wed Apr 03 2019 7:55pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Is this the setting to tell the car if it's a traditional lead acid battery , compared to an AGM one?
Thu Apr 04 2019 7:28am |
Extract from Workshop Manual, no mention of Lead Acid or AGM.
Thu Apr 04 2019 7:35am |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
.but you don't actually need to do that, as the BMS will "learn" the characteristics of the new battery over time. Or at least it does on Jags. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Thu Apr 04 2019 8:24am |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
Resetting the BMS is only required if you are not fitting like with like i.e. AGM with new AGM no reset required. |
Thu Apr 04 2019 11:44am |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
Fitted my Nov 2010 MY2011 with a Yuasa HSB019 Silver in 2015 and it’s been an epic performer. I’m a low mileage driver and use remote cabin heating. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Thu Apr 04 2019 9:52pm |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 |
Exide Premium EA1000 2007 TDV6 RRS HSE..now gone
Fri Apr 05 2019 12:45am |
That’s the Halfords number for the HBX5019, mine is the HSB020 silver, I only got it from Halfords as it was under a £100 with my trade card. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Fri Apr 05 2019 5:38am |
Thanks for the comments and contributions folks.
Tue Apr 09 2019 11:32am |
You will not need any codes when swapping battery, if I remember correctly all you will have to do is reset the date as it defaults to 2009 and reset the electric windows "one touch operation" easy enough, also the sunroof if you have one. As far as the BMS is concerned reset it if you have a diag. tool, if not apparently they do periodically do a self calibration test so not a real issue, I think I would just make sure the new battery is fully charged before fitting it. I replaced my Lead Acid with a AGM and never changed any setting on the car to say it had been changed to AGM that was three years ago and have never had any battery issues at all.
Tue Apr 09 2019 8:53pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
A few guys on here have used Tanya batteries as their was a bit discount available I think,, I did the same but can't remember the exact model. If you do a search you will find more info. 2010 RRS, TDV8
Wed Apr 10 2019 5:22am |
