Home > Maintenance & Modifications > MY10 RRS New Battery advice
GSJ
Wales 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Morning All,
This has probably been covered, but just for completeness I thought id ask the question.
Ive had a few faults popping up on dash recently, and the car maybe a little laboured to start up..not too bad, but this morning (quite cold) the car wont start. Charged it for 20 mins, and it fired up.
Ive heard that a drop in voltage can throw up a few warnings on the dash (susp, hdc, traction, etc) so is it worth swapping old battery out for a new one?
If so, what should I be looking for? Amps? Cranking? Confused Confused Confused
Any advice folks?
Thanks in advance
Gar
Post #578346 Wed Apr 03 2019 9:47am
Brit Plumber
Go for the best you can fit in the tray. I’ve fitted one rated for the Diesals. Yuasa YBX5020 110Ah, 900A. The original was a 90Ah, 850A Land Rover Varta which equates to the Yuasa YBX5019. The bigger battery was 1 inch longer so was a tight fit but it went in.
I also updated the CCF with the new details as I believe the car charges the battery in a pattern matched to the battery capacity. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #578353 Wed Apr 03 2019 1:06pm
GSJ
Hey Brit Plumber,
Thanks for the reply. Whats CCF?
cheers
Gar
Post #578354 Wed Apr 03 2019 1:12pm
Brit Plumber
The car configuration file. It lists all the options on the car that need activation to work amongst other things. I believe the car needs to know what battery is fitted so it can charge it in the appropriate manner. 2019 5.0 SC SVA (Current)
Post #578357 Wed Apr 03 2019 2:31pm
Could never work out which to set mine to when upgraded the battery as the particular/size rating was not mentioned in the CCF so left it as was and have had no issues, there is some setting I remember which should be reset so the car knows it has had new battery which relates to the battery monitoring system on the facelift variant if I remember correctly. Although told car works it out for it's self over time don't know if that is correct though, was told that by a Indi.
Post #578379 Wed Apr 03 2019 8:55pm
Oldandconfused
Is this the setting to tell the car if it's a traditional lead acid battery , compared to an AGM one?
If you are replacing like for like,AFAIK you don't need to do anything (e.g let the car to to sleep, disconnect the -ve first etc)
Post #578393 Thu Apr 04 2019 8:28am
Extract from Workshop Manual, no mention of Lead Acid or AGM.
8 BATTERY REPLACEMENT
If it is determined that a battery requires replacement, always refer to the appropriate section of the workshop
manual for instructions on removing and installing the battery from the vehicle.
On in service vehicles fitted with a Battery Monitoring System (BMS), the BMS module must be reset following the
installation of a new battery. The BMS module reset procedure must be performed using an approved diagnostic
system.
Post #578396 Thu Apr 04 2019 8:35am
wilf
.but you don't actually need to do that, as the BMS will "learn" the characteristics of the new battery over time. Or at least it does on Jags. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #578400 Thu Apr 04 2019 9:24am
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
Resetting the BMS is only required if you are not fitting like with like i.e. AGM with new AGM no reset required.
Post #578403 Thu Apr 04 2019 12:44pm
ilard
Fitted my Nov 2010 MY2011 with a Yuasa HSB019 Silver in 2015 and it’s been an epic performer. I’m a low mileage driver and use remote cabin heating. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #578434 Thu Apr 04 2019 10:52pm
MGO
Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Exide Premium EA1000 2007 TDV6 RRS HSE..now gone
2012 3.0 SDV6 RRS HSE
Post #578440 Fri Apr 05 2019 1:45am
Brit Plumber
That’s the Halfords number for the HBX5019, mine is the HSB020 silver, I only got it from Halfords as it was under a £100 with my trade card. 2019 5.0 SC SVA (Current)
Post #578444 Fri Apr 05 2019 6:38am
GSJ
Thanks for the comments and contributions folks.
Still none the wiser whether I can slot in a replacement battery or not without having to reset anything (BMS).
Also, before I forget, if I swop out the battery, will I need any codes to ensure car systems work? Ie radio code?
anybody swop out a battery and not need any codes inputting?
cheers
Gar
Post #578659 Tue Apr 09 2019 12:32pm
You will not need any codes when swapping battery, if I remember correctly all you will have to do is reset the date as it defaults to 2009 and reset the electric windows "one touch operation" easy enough, also the sunroof if you have one. As far as the BMS is concerned reset it if you have a diag. tool, if not apparently they do periodically do a self calibration test so not a real issue, I think I would just make sure the new battery is fully charged before fitting it. I replaced my Lead Acid with a AGM and never changed any setting on the car to say it had been changed to AGM that was three years ago and have never had any battery issues at all.
Post #578690 Tue Apr 09 2019 9:53pm
gogsy1956
A few guys on here have used Tanya batteries as their was a bit discount available I think,, I did the same but can't remember the exact model. If you do a search you will find more info. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #578702 Wed Apr 10 2019 6:22am
