Home > Technical > Rear suspension drop |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8999 |
First of all, check that it isn't an electronics issue. You can pull the fuse that controls the air suspension and see if it still drops. If it does, then it's most likely an air leak. The only common part between the two rear corners is the valve block. It might have some muck in it from the air dryer. The air drier is part of the compressor and it's not unknown for some of that material in it to be blown through the system as it ages. That could then stop the valves closing fully.
Mon Apr 01 2019 8:19am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4982 |
of you can get seals for £15 ish off ebay.
Mon Apr 01 2019 11:02am |
Jackiet Member Since: 31 Mar 2019 Location: South Yorkshire Posts: 17 |
Hi
Mon Apr 01 2019 11:06am |
It's kinda between the spare wheel and the left rear wheel arch.
Mon Apr 01 2019 11:51am |
Ok thanks I will have a look. |
Mon Apr 01 2019 1:41pm |
Hi
Thu Apr 04 2019 10:03pm |
This morning the NSR is very low but the OSR isn’t as bad (previously they were both on the bump stops) something’s improved slightly. Wonder if the pipes/fittings are leaking ? |
Fri Apr 05 2019 9:47am |
Check the pipe to the low side.
Fri Apr 05 2019 11:02am |
I’ve been round the rear valve block and pipe fittings etc with some soapy water but no sign of leaks/bubbles, however I did find bubbling around the blue connector on the dryer top, hopefully this is the problem. |
Fri Apr 05 2019 7:59pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Are the bubbles at the front of the compressor where the pipes come out? If so its a plastic cover held in with about 6 screws and they crack between the pipe exit points. I had this on my 2005 D3 and bought an aluminium cap off the bay of fleas for about £30 and replaced it myself. on the drive It cured the compressor problem, but I didn't have any suspension drop problems that you have. May not be connected and you have two issues.
Sat Apr 06 2019 8:43am |
while its good to sort the compressor cap (and fairly easy) as it will extend its life significantly. I don't think that issues causes drop.
Sat Apr 06 2019 8:52am |
Hi
Sat Apr 06 2019 10:43am |
Hi
Sat Apr 06 2019 6:56pm |
You changed that quickly the second time.
Sat Apr 06 2019 7:54pm |
