![]() | Home > Technical > Level sensor issue |
I always thought when replacing a height sensor you should recalibrate the height again, probably what the issue is i would say |
sid1968 Member Since: 16 Aug 2015 Location: lancashire Posts: 12 ![]() ![]() ![]() |
If it needs re claribratin would a suspension fault show?? Even if it looks level visually
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Or it could have been a sensor wiring fault in the first place. |
But the original sensor was not throwin any faults?? |
Completely broken an intermittent wire ? |
Does it need re clarabatin on a sensor fit??
It requires calibration but shouldn’t be so bad it puts the light on.
