Home > Technical > Level sensor issue
sid1968
United Kingdom 2005 Range Rover Sport TDV6 Autobiography Java Black
Level sensor issue
Hi
Replaced rear right level sensor on a RR sport 2006. the original was temperamental. with no errors but on the denso screen 4x4 setting the back rear wheel was showing jumpy..
Replaced the level sensor now coming up with a suspension fault with a car sign and arrow. The level sensor is a aftermarket part.
could that be faulty?? or does it need setting via diagnostics kit.
Note: in the 4 x 4 settings the rear right wheel is showing lower than the other 3 with a red line underneath but the car looks pretty level from the rear
any advice please much appreciated in advance
Post #578159 Sat Mar 30 2019 4:08pm
Buckster
I always thought when replacing a height sensor you should recalibrate the height again, probably what the issue is i would say Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #578161 Sat Mar 30 2019 4:36pm
sid1968
If it needs re claribratin would a suspension fault show?? Even if it looks level visually
Don't want buy another one if this is the case
Thanx in advance
Post #578165 Sat Mar 30 2019 5:08pm
Or it could have been a sensor wiring fault in the first place.
Post #578169 Sat Mar 30 2019 6:07pm
sid1968
But the original sensor was not throwin any faults??
Post #578170 Sat Mar 30 2019 6:32pm
Completely broken an intermittent wire ?
Post #578171 Sat Mar 30 2019 6:42pm
sid1968
Does it need re clarabatin on a sensor fit??
Would it throw a suspension fault on a replacement?? Until recalabration??
Post #578172 Sat Mar 30 2019 6:46pm
It requires calibration but shouldn’t be so bad it puts the light on.
Not sure what happens if you replace sensor without disconnecting battery. 😔
Maybe worth clearing the codes or removing the 20A fuse under the bonnet, for a bit
Post #578173 Sat Mar 30 2019 7:02pm
