![]() | Home > Technical > L320 Folding Rear seats how ? 2012 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5067 ![]() ![]() ![]() |
I assume you have hinged the seat cushion forward first.
You’ll find at the back of the seat cushion (the bum bit) a material lug that you can grab and pull the seat base up and over into the footwell, then bring the backs down. Sometimes the lug gets tucked away out of sight but you should feel it.
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
Thanks guys will take a look ,
If in doubt read the instructions |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
If your a tall driver you won't like this, at the drivers seat can't be in the fully reward position |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 395 ![]() ![]() ![]() |
Taking the rear headrests off helps with getting the seat back down flat too Merc C220 estate Sport AMG
You'll probably find that the tabs for pulling up the seat bases have disappeared behind the seats, you'll have to fish for them,,, always happens on mine. Lower the headrests as far as they'll go. 2010 RRS, TDV8
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
I've looped a long plastic cable tie around each of the seat tags. You can hide them behind the seat but it's a hell of a lot easier to pull them out when you need them. Barrie.
Seats down , just needed to pull the little cords on the bottom of each seat, so thanks for that
that's a nice light interior you have |
