Home > General (L494) > Rotating wheels front to back
m13lky
Got a puncture, screw in my front offside tyre, fitted full size spare yesterday & got it repaired today no problems, when I was refitting I thought I would rotate the wheels front to rear & vice versa, now it seems after setting & checking the pressures, the Tpms seems to show/know the rear wheel is on the front & vice versa? I assume you must have to recalibrate the valve sensors?
This is a bit of a pain as although all my tyres seem to be wearing evenly, all 6mm across all 4 tyres after 10k, the 2 fronts have slight feathering on the outer edges so this is the reason I was going to rotate them.
Has anyone had the same issue? If so can you reset the system without paying the dealer to do it? I’ve checked the handbook & there is no resetting procedure/button mentioned.
It’s a l494 ab my17.5
Malc
Post #577316 Mon Mar 18 2019 7:05pm
Tim in Scotland
IIRC in the owner’s manual you need to take it for a 15 minute drive to let the sensors pick up the new location of the wheels 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #577317 Mon Mar 18 2019 7:28pm
timhum
Exactly what I do when changing from winter to summer tyres, the car soon sorts itself out.
Tim Tim
RRS sold and replaced with a Skoda Kodiaq after appalling RR Dealer experience and LR inability to supply new cars in any sort of reasonable time frame..
Post #577318 Mon Mar 18 2019 7:40pm
Tyrefitter
As Tim says,,,,you can fit the wheels anywhere on the sport & it will pick the signal up after a drive.Ive fitted loads & when I take them off they never all go back on the same corner & ive never had a problem with them,,Infact I’ve just swapped my sport & I kept my wheels which the dealer swapped over for me & all the sensors connected by the time I’d driven out of the workshop. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #577319 Mon Mar 18 2019 7:41pm
m13lky
Great thanks guys, I have driven it but only around half a mile to the fuel station & back, will go for a drive later, thanks again!
Saves me swapping wheels round again!
Malc
Post #577320 Mon Mar 18 2019 7:44pm
