Home > General (L494) > Blind sport detection...or not! |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1854 |
The indication is in the mirrors not on the dash. 2023 P440e SE Dynamic on order -cancelled
Sat Mar 16 2019 1:34pm |
29salcombe Member Since: 08 Jan 2013 Location: Cornwall Posts: 38 |
Jimbg, I know I should get the amber warning in the mirrors. But I'm not? But if it had failed I would expect I would get a warning in the dash? |
Sat Mar 16 2019 1:47pm |
Sorry misread your comment about the amber light in the mirror when is OFF. 2023 P440e SE Dynamic on order -cancelled
Sat Mar 16 2019 1:55pm |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
The behaviour you describe sounds like it should work. The ‘dot’ light in the mirror is only illuminated when the car is below a certain speed (i.e. the blind spot monitor isn’t supposed to kick in), you have it turned off in the menu or there is a fault with the system. At all other times that light should not be on. When there is a vehicle in your blind spot, the other light in the mirror with the car symbol should come on. If you have closing vehicle sensing as well and a car is approaching fast from behind, the car symbol light should flash. Your car needs to be travelling above the minimum speed threshold for these systems to work.
Sat Mar 16 2019 4:02pm |
I was on a dual carriage way. The weather was heavy rain and spray, maybe that could be an issue? |
Sat Mar 16 2019 5:52pm |
scriv Member Since: 28 Jul 2012 Location: kent Posts: 93 |
Mine stopped working also
Sat Mar 16 2019 6:15pm |
That certainly could be an issue but it should show a triangle and message on the dash when that happens. In my last car I had the problem once while driving in heavy rain and twice while in heavy snow. In case of rain, the problem went away when I left the car and came back to it later. When it was because of snow, the issue went away when the snow and ice buildups melted away. However, on each occasion I got clear message on the dash (and an audible alert as well IIRC). Something along the lines of “blind spot sensor blocked, system unavailable”. Every time I cleared the fault (using IIDTool) or disabled/enabled the feature, the fault came back on the dash. That’s why I’m surprised yours has done it silently. Mine was a 16MY so may be something different there. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond |
Sat Mar 16 2019 8:44pm |
Thank you everyone for all your comments and advice. The car is new to me (picked it up Friday) So I will feedback my findings to the dealer I purchased the car from. Unfortunately I live in Cornwall and the dealer (not Land Rover) is in Wigan.
Sun Mar 17 2019 7:32am |
http://www.ownerinfo.landrover.com/documen...c/G1797365
Sun Mar 17 2019 8:33am |
Spleen Member Since: 04 Dec 2018 Location: Berkshire Posts: 175 |
I'll swap you my passenger side sensor if you like as it has a mind of its own and sees stuff that isn't there. Hardly noticeable during the day but a pain in the arse at night as it just goes off on one randomly. However, as there are no fault codes the dealer won't/can't fix it. FFS. Ferrari F430 Spider F1
Sun Mar 17 2019 11:01am |
tmann45 Member Since: 11 Nov 2017 Location: Texas Posts: 1 |
sounds like your on/off indication might be backwards. If you get amber lights in mirrors when off, turn off and go for a test drive. |
Mon Mar 18 2019 8:21am |
Spleen, in my last 4 Land Rovers all with BLIS the local overhanging shrubbery on the country lanes where I live used to trigger warnings on the passenger side, it rendered the system useless on country roads with overgrown verges. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Mar 18 2019 9:08am |
Cheers Tim, trouble is it fires off when I'm overseas as well and also if I'm barrelling down the motorway with all in front or behind. It's pretty frustrating. The worst is at night when overtaking on the motorway, I know I'm way past the car on my left and yet the thing goes berserk when indicating which just just puts me on edge. My last car didn't have this functionality and I managed just fine so I may just disable it next time I'm home. Ferrari F430 Spider F1
Mon Mar 18 2019 10:35pm |
Sounds like a visit to the dealers to sort it out is required 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Mar 18 2019 10:56pm |
