Home > General (L494) > Blind sport detection...or not!
29salcombe
2013 Range Rover Sport 3.0 TDV6 HSE Izmir Blue
I have had my L494 2014 for a day. But I've just gone for a drive and noticed the blind spot detection not working? I got no warning on the dash. I went in to the driver features and switch it off which lit up a some amber light on each mirror. I switched it back on and the amber lights went out on each mirror but the system wasn't working????
Any ideas??? Thumbs Up
Post #577158 Sat Mar 16 2019 2:30pm
jimbg
The indication is in the mirrors not on the dash. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #577159 Sat Mar 16 2019 2:34pm
29salcombe
Jimbg, I know I should get the amber warning in the mirrors. But I'm not? But if it had failed I would expect I would get a warning in the dash?
Post #577160 Sat Mar 16 2019 2:47pm
jimbg
Sorry misread your comment about the amber light in the mirror when is OFF. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #577161 Sat Mar 16 2019 2:55pm
fkarim
The behaviour you describe sounds like it should work. The ‘dot’ light in the mirror is only illuminated when the car is below a certain speed (i.e. the blind spot monitor isn’t supposed to kick in), you have it turned off in the menu or there is a fault with the system. At all other times that light should not be on. When there is a vehicle in your blind spot, the other light in the mirror with the car symbol should come on. If you have closing vehicle sensing as well and a car is approaching fast from behind, the car symbol light should flash. Your car needs to be travelling above the minimum speed threshold for these systems to work.
In the absence of a fault, it should just work in my experience. The fact that you disabled and re-enabled the setting in the menu rules out the possibility that you missed the fault on the dash first time round because after rexenabling, the triangle and a message would immediately appear on the dash.
Try disabling and re-enabling closing vehicle sensing also (if you have it). Lock the car, let it go to sleep and check again after a while. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #577168 Sat Mar 16 2019 5:02pm
29salcombe
I was on a dual carriage way. The weather was heavy rain and spray, maybe that could be an issue?
Post #577181 Sat Mar 16 2019 6:52pm
scriv
United Kingdom 2013 Range Rover Sport Supercharged Siberian Silver
Mine stopped working also
Dealer had it in rear bumper was full of mud and blocked the sensors they said I must off-road it to much LOL
It was all fixed under warranty together with inner wheel arch being replaced
Post #577182 Sat Mar 16 2019 7:15pm
fkarim
That certainly could be an issue but it should show a triangle and message on the dash when that happens. In my last car I had the problem once while driving in heavy rain and twice while in heavy snow. In case of rain, the problem went away when I left the car and came back to it later. When it was because of snow, the issue went away when the snow and ice buildups melted away. However, on each occasion I got clear message on the dash (and an audible alert as well IIRC). Something along the lines of “blind spot sensor blocked, system unavailable”. Every time I cleared the fault (using IIDTool) or disabled/enabled the feature, the fault came back on the dash. That’s why I’m surprised yours has done it silently. Mine was a 16MY so may be something different there. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Post #577188 Sat Mar 16 2019 9:44pm
29salcombe
Thank you everyone for all your comments and advice. The car is new to me (picked it up Friday) So I will feedback my findings to the dealer I purchased the car from. Unfortunately I live in Cornwall and the dealer (not Land Rover) is in Wigan.
I'm hoping leaving the car overnight It might reset everything (fingers crossed)
And... how on earth do you check the oil level???? Bow down
Post #577195 Sun Mar 17 2019 8:32am
jimbg
http://www.ownerinfo.landrover.com/documen...c/G1797365
There is an online manual you can read or the hard copy one that you should have? Thumbs Up 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #577198 Sun Mar 17 2019 9:33am
Spleen
I'll swap you my passenger side sensor if you like as it has a mind of its own and sees stuff that isn't there. Hardly noticeable during the day but a pain in the arse at night as it just goes off on one randomly. However, as there are no fault codes the dealer won't/can't fix it. FFS. Ferrari F430 Spider F1
MY17 RRS AB V6
2CV6 Special
Post #577213 Sun Mar 17 2019 12:01pm
tmann45
United States
Re: Blind sport detection...or not!
sounds like your on/off indication might be backwards. If you get amber lights in mirrors when off, turn off and go for a test drive.
Post #577285 Mon Mar 18 2019 9:21am
Tim in Scotland
Spleen, in my last 4 Land Rovers all with BLIS the local overhanging shrubbery on the country lanes where I live used to trigger warnings on the passenger side, it rendered the system useless on country roads with overgrown verges. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #577291 Mon Mar 18 2019 10:08am
Spleen
Cheers Tim, trouble is it fires off when I'm overseas as well and also if I'm barrelling down the motorway with Censored all in front or behind. It's pretty frustrating. The worst is at night when overtaking on the motorway, I know I'm way past the car on my left and yet the thing goes berserk when indicating which just just puts me on edge. My last car didn't have this functionality and I managed just fine so I may just disable it next time I'm home. Ferrari F430 Spider F1
MY17 RRS AB V6
2CV6 Special
Post #577327 Mon Mar 18 2019 11:35pm
Tim in Scotland
Sounds like a visit to the dealers to sort it out is required 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #577328 Mon Mar 18 2019 11:56pm
