![]() | Home > General > Best place to get plastic trim clips |
I always get my clips from eBay. I've mainly bought interior ones so far. I now always buy more than I need to build up a little stock that I keep in the boot tool tray as they always come in handy. Kev
http://www.rrsport.co.uk/forum/topic53266....trim+clips In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Yellow and White colour clips part number DYC101420
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
Thank you - £2.62 + VAT each from LR dealer - hand-carved from the tusks of albino unicorns by mermaids. |
For what ever reason L/R also use the one piece black plastic clips DYC500110 at each end of the front door the rest being the yellow/white ones. The black ones are only used on front doors not rears, go figure that one.
![]() MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
I wouldn't bother with the two-part yellow and white clips. I found that if the trim piece gets ripped off when off road, those clips never work properly again. I ended up using duct tape to stop one of the trims flapping about. Then I decided to use all black clips along the trim piece and the trim stayed in place. 2012 SDV6 - it's missing a couple of cylinders
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 ![]() ![]() |
I used all black clips on my old one, much better than the 2 piece ones |
Although the black one piece ones are far better, the only slight downside is if you need to remove the trim for any reason if the clip doesn't break then the retaining part on the trim it's self will, with the two piece one the clip will separate and not destroy the trim, guess it's which is the lesser of two evils, as the two piece one's fall apart anyhow.
