Home > General > Best place to get plastic trim clips
HughN
Wales
Quick question...
Where's the best place to get the black trim clips such as those that hold the trim on the lower part of the door?
Thanks,
Hugh
Post #577057 Fri Mar 15 2019 8:47am
knwatkins
I always get my clips from eBay. I've mainly bought interior ones so far. I now always buy more than I need to build up a little stock that I keep in the boot tool tray as they always come in handy. Kev
Post #577065 Fri Mar 15 2019 12:12pm
SRE
Spain
http://www.rrsport.co.uk/forum/topic53266....trim+clips In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #577068 Fri Mar 15 2019 1:10pm
SRE
Spain
Yellow and White colour clips part number DYC101420
It's the same clip for the tailgate trim as well.
https://www.lrdirect.com/search.php?mode=search&page=1 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #577069 Fri Mar 15 2019 1:15pm
HughN
Wales
Thank you - £2.62 + VAT each from LR dealer - hand-carved from the tusks of albino unicorns by mermaids.
Post #577083 Fri Mar 15 2019 4:31pm
For what ever reason L/R also use the one piece black plastic clips DYC500110 at each end of the front door the rest being the yellow/white ones. The black ones are only used on front doors not rears, go figure that one.
Post #577125 Sat Mar 16 2019 1:02am
knwatkins
Laughing Kev
Post #577130 Sat Mar 16 2019 8:11am
I wouldn't bother with the two-part yellow and white clips. I found that if the trim piece gets ripped off when off road, those clips never work properly again. I ended up using duct tape to stop one of the trims flapping about. Then I decided to use all black clips along the trim piece and the trim stayed in place. 2012 SDV6 - it's missing a couple of cylinders
Post #577149 Sat Mar 16 2019 10:11am
jason-nike
I used all black clips on my old one, much better than the 2 piece ones
Post #577164 Sat Mar 16 2019 3:18pm
Although the black one piece ones are far better, the only slight downside is if you need to remove the trim for any reason if the clip doesn't break then the retaining part on the trim it's self will, with the two piece one the clip will separate and not destroy the trim, guess it's which is the lesser of two evils, as the two piece one's fall apart anyhow.
Post #577187 Sat Mar 16 2019 7:02pm
