Home > Technical > scraping noise coming from new brakes |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 |
what garage was it?
Wed Mar 13 2019 10:30am |
f11rfn Member Since: 25 Apr 2014 Location: england Posts: 21 |
its a independant garage, been using them for quite long time, the scraping noise was not there before i changed the brakes, its appeared after, had mot 2 months ago no advisories on anything, and both bearings have been changed, but the pedal is still soft, is it possible the pads have not been inserted correctley? as after a short drive the discs are very hot or is this normal?
Wed Mar 13 2019 10:38am |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
Sounds like you may have a couple of issues.
Wed Mar 13 2019 12:27pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
That garage is to be avoided Visitor from fullfatrr.com
Wed Mar 13 2019 4:40pm |
Where are you located? We can collectively recommend somewhere. Your profile is too generic Visitor from fullfatrr.com
Wed Mar 13 2019 4:41pm |
it has slight wobble in straight not braking, had the balancing done aswell, only had front brakes done and we checked if the brake cover is hitting but its clear, also it only started making this noise after the brakes were chnaged, the calipers are new, if the brakes are not bled properley could this cause the caliper to stick? |
Wed Mar 13 2019 5:18pm |
im based in birmingham |
Wed Mar 13 2019 5:19pm |
Sorry, don’t know anyone there....
Wed Mar 13 2019 7:05pm |
ok thanks |
Wed Mar 13 2019 10:51pm |
ATL in Dudley which is just up the road from you. |
Thu Mar 14 2019 7:10am |
After you’ve driven a while, splash some water on your discs to see if they hiss. I reckon the pistons are corroded or dirty. When pads are changed the material is much thicker and the previously exposed section of piston now need to slide in and out of the caliper. They can come out ok under brake pressure but don’t go in as well as there’s no pressure to withdraw them. My opinion is you need a caliper and piston clean up and possibly an overhaul. As for the wobble, do you have a light chattering through the wheel when driving slow over a reasonably uneven road? 2019 5.0 SC SVA (Current)
Thu Mar 14 2019 10:42am |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
I think Brit got it right. look at your calipter pistons and leaking rubbers RRS 3.0 SDV6 HSE Lux
Thu Mar 14 2019 10:53am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4968 |
If I'm reading the original post correctly the OP has already had new callipers fitted and the fault is still there, but I could be wrong, could the guide pins/slide be partially siezed causing caliper to stick if that is the cause of the noise.
Thu Mar 14 2019 11:33am |
Deleted my reply as Col has said, I missed the last part of the OPs message stating the callipers had been replaced.
Thu Mar 14 2019 12:15pm |
