Home > General > Do I have to use LR bulbs? |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8977 |
They can cause a problem but so long as the ones you get are reasonable quality e.g. Osram, you should be ok. I think it's the cheap-as-chips ebay ones that are the biggest culprit. 2012 SDV6 - it's missing a couple of cylinders
Tue Mar 05 2019 10:30am |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 409 |
I've replaced bulbs with good quality ones with no problems. Barrie.
Tue Mar 05 2019 12:05pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4944 |
well i wouldn't get them from halfords.
Tue Mar 05 2019 12:07pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
One of the first things I did on my old D3, used genuine LR bulbs, bought a couple of spares as well. I had a couple of ESF turbo warning lights on the dash, changed the bulbs, no more issues. I used up the last one the other week on the wife's' Mokka (I know, don't laugh). |
Tue Mar 05 2019 7:58pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
I think you will find that Oshino are OEM suppliers to JLR In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Wed Mar 06 2019 12:59pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Well I went to my local motor factors and explained about the bulb. Hella he said is a good brand, so I got it. Got home and fitted it, then drove away to take the dogs out. The car would now not change gear but would manually. I got to my destination relatively locally and found that all 3 brake lights were permanently on with the lights switched on. With the lights off all 3 were still lit with the ignition on. I removed the bulb and all returned to the previous fault. At the mo I have 2 brake lights and will drop by the dealer on Monday, probably get a spare bulb kit while I’m there to make the journey worthwhile.
Sat Mar 09 2019 3:07pm |
Did it have 2 contacts on the bottom ?
Sat Mar 09 2019 3:13pm |
Yep. P21/5W. Made in Thailand L7. Twin filament with the 2 nipples.
Sat Mar 09 2019 4:12pm |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
Check that bulbs have not been fitted the wrong way round. If the pins are not staggered this is a possibility.
Sun Mar 10 2019 5:41am |
I went to Halfords this morning and purchased GE branded bulb (3 times the life) & the most expensive. Fitted the bulb and everything works as designed. I retrieved the blown bulb which was Osram.
Sun Mar 10 2019 11:20am |
