Home > General > Do I have to use LR bulbs?
Stevepd
I have a brake light bulb gone today. Something is sticking in my mind that you’d be better off buying LR supplied bulbs as others cause spurious faults. I know LR don’t make the bulbs, so am I ok buying branded bulbs from Halfords (6 miles away) as my LR dealer is over 20 miles away.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #576421 Tue Mar 05 2019 10:19am
They can cause a problem but so long as the ones you get are reasonable quality e.g. Osram, you should be ok. I think it's the cheap-as-chips ebay ones that are the biggest culprit. 2012 SDV6 - it's missing a couple of cylinders
Post #576423 Tue Mar 05 2019 10:30am
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
I've replaced bulbs with good quality ones with no problems. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #576427 Tue Mar 05 2019 12:05pm
well i wouldn't get them from halfords.
But you should be able to get quality bulbs from somewhere.
Maybe try a petrol filling station, and then maybe get some mail ordered for spares
Post #576428 Tue Mar 05 2019 12:07pm
Oldandconfused
One of the first things I did on my old D3, used genuine LR bulbs, bought a couple of spares as well. I had a couple of ESF turbo warning lights on the dash, changed the bulbs, no more issues. I used up the last one the other week on the wife's' Mokka (I know, don't laugh).
Post #576465 Tue Mar 05 2019 7:58pm
SRE
Spain
I think you will find that Oshino are OEM suppliers to JLR In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #576509 Wed Mar 06 2019 12:59pm
Stevepd
Well I went to my local motor factors and explained about the bulb. Hella he said is a good brand, so I got it. Got home and fitted it, then drove away to take the dogs out. The car would now not change gear but would manually. I got to my destination relatively locally and found that all 3 brake lights were permanently on with the lights switched on. With the lights off all 3 were still lit with the ignition on. I removed the bulb and all returned to the previous fault. At the mo I have 2 brake lights and will drop by the dealer on Monday, probably get a spare bulb kit while I’m there to make the journey worthwhile.
The bulb sold to me was Hella and in the smallest print I found made in Thailand.
Post #576740 Sat Mar 09 2019 3:07pm
Did it have 2 contacts on the bottom ?
And 21/5W on it?
Post #576742 Sat Mar 09 2019 3:13pm
Stevepd
Yep. P21/5W. Made in Thailand L7. Twin filament with the 2 nipples.
Post #576745 Sat Mar 09 2019 4:12pm
Bardley
Check that bulbs have not been fitted the wrong way round. If the pins are not staggered this is a possibility.
Also worth noting that the brake light switch is a known issue on the D4, so it maybe worth checking too. 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #576768 Sun Mar 10 2019 5:41am
Stevepd
I went to Halfords this morning and purchased GE branded bulb (3 times the life) & the most expensive. Fitted the bulb and everything works as designed. I retrieved the blown bulb which was Osram.
GE Thumbs Up
Osram Thumbs Up
Hella Censored
Post #576796 Sun Mar 10 2019 11:20am
