Home > Maintenance & Modifications > Check your oil there is no low level warning |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 |
bring back the dip stick i say!
Tue Mar 05 2019 4:40pm |
Tue Mar 05 2019 5:18pm |
the new sport must allow the level to read without the engine warmed up so...
Tue Mar 05 2019 5:20pm |
just checked the operator manual
Tue Mar 05 2019 8:45pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
Surely the low oil pressure light would start to come on as the oil level got down to the level of the pickup. 07MY RRS TDV6 Arctic Frost Aspen Interior |
Tue Mar 05 2019 10:47pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
The low pressure oil light should be renamed the “fit a new engine light”. There is no oil level low light in the RRS1, which when there is no dipstick, except the one behind the wheel, is IMHO a major design fault. |
Wed Mar 06 2019 4:24pm |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 531 |
Wed Mar 06 2019 6:48pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4948 |
So having the bonnet open allows you to bypass the wait system ? |
Wed Mar 06 2019 7:57pm |
i'll try it in the morning.
Wed Mar 06 2019 8:12pm |
Doesn’t work on mine, the oil has to be warm and I have to wait 10 mins after engine off or it tells me oil level not available. 2019 5.0 SC SVA (Current)
Wed Mar 06 2019 8:32pm |
Wed Mar 06 2019 8:53pm |
I’ll give it a go, I always forget to check after 10 mins so that would be god send. 2019 5.0 SC SVA (Current)
Wed Mar 06 2019 8:58pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
So that’s potentially running on low oil for 10 mins until the system tells your low on oil .
Thu Mar 07 2019 7:32am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
Strange, mine checks o.k. whether checked after stopping for 10 mins. or left overnight and checked in morning when cold, don't have to press any cruise control buttons, open bonnet or anything like that. Of course I am assuming it works o.k. but never put any oil in between services and it hasn't gone bang yet. Could just lift throttle pedal slightly as if pressed at all when checking it will say not available or whatever it says.
Thu Mar 07 2019 9:15am |
