![]() | Home > Maintenance & Modifications > Check your oil there is no low level warning |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 ![]() ![]() ![]() |
bring back the dip stick i say!
the new sport must allow the level to read without the engine warmed up so...
just checked the operator manual
Surely the low oil pressure light would start to come on as the oil level got down to the level of the pickup. 07MY RRS TDV6 Arctic Frost Aspen Interior |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
The low pressure oil light should be renamed the “fit a new engine light”. There is no oil level low light in the RRS1, which when there is no dipstick, except the one behind the wheel, is IMHO a major design fault. |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 546 ![]() ![]() |
So having the bonnet open allows you to bypass the wait system ? |
i'll try it in the morning.
Doesn’t work on mine, the oil has to be warm and I have to wait 10 mins after engine off or it tells me oil level not available. 2019 5.0 SC SVA (Current)
I’ll give it a go, I always forget to check after 10 mins so that would be god send. 2019 5.0 SC SVA (Current)
So that’s potentially running on low oil for 10 mins until the system tells your low on oil |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
Strange, mine checks o.k. whether checked after stopping for 10 mins. or left overnight and checked in morning when cold, don't have to press any cruise control buttons, open bonnet or anything like that. Of course I am assuming it works o.k. but never put any oil in between services and it hasn't gone bang yet. |
