Home > Maintenance & Modifications > Dynamic Response system removal
Disco_Mikey
Has anyone managed this on a 3.0 2010 car? Have a car in tomorrow with the view to carrying this out
Have done plenty of 2.7's, fairly popular due to the relative expense involved when there is a pipework/hydraulic actuator problem.
Removing the system and fitting standard ARB's in place is a cheaper and much more reliable
On this car in question, the ARC pumped has failed, contaminated the system and both bars are leaking, and requiring an estimated £7k repair Shocked
However, both LR and Autologic both tell me its not possible on a 3.0 2010-2012 car...
Post #575839 Sun Feb 24 2019 11:11pm
Buckster
Cant help but when my rear ARB with Dynamic response leaked all its oil out i had to have a whole new rear ARB. I believe its a partial body lift on the rear to remove due to the space involved. Total cost was around £2.5k with genuine parts and Labour but LR Warranty picked up the tab Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #575840 Sun Feb 24 2019 11:34pm
On the later ones, dynamic response will be tied in to the Terrain Response system to allow the Dynamic road program. On the earlier ones, dynamic response was stand alone.
I can see that removing DR whilst keeping TR happy would be very tricky. 2012 SDV6 - it's missing a couple of cylinders
Post #575846 Mon Feb 25 2019 12:09am
Disco_Mikey
Just to close this off, system removed and disabled, with no warning lights
TR remains active, as do all the ABS/DSC functions
Post #576145 Fri Mar 01 2019 9:06pm
Ooh, well done. Was it difficult with lots of swearing or straight forward? 2012 SDV6 - it's missing a couple of cylinders
Post #576149 Fri Mar 01 2019 10:07pm
Disco_Mikey
Hardware was relatively easy
Software took a bit of head scratching, but essentially the same process as the 2.7
Just need a 3.6 to try it on now, but no reason to assume it won't work, other than finding the correct length of drive belt Confused
Post #576163 Sat Mar 02 2019 9:05am
DrRob
I’m certain that will be a popular conversion in the future to avoid huge bills Visitor from fullfatrr.com
Post #576170 Sat Mar 02 2019 9:52am
Disco_Mikey
As the cars age, and decrease in value, cheaper repairs are always welcome Thumbs Up
Post #576173 Sat Mar 02 2019 9:55am
It'll ruin some TDV8s, sadly. But then if someone wants to do cheap fixes it's probably a shed already, or rapidly headed that way. Big Cry 2012 SDV6 - it's missing a couple of cylinders
Post #576222 Sat Mar 02 2019 8:29pm
Disco_Mikey
I was going to attempt my TDV8 without transferring all the ARC stuff over, but thought I had best keep it. The D3 has a lot more weight/height to control, so its probably a good idea to keep it Laughing
Post #576224 Sat Mar 02 2019 8:33pm
BernHard
Australia 2011 Range Rover Sport TDV8 Autobiography Java Black
Discovery 4 with RRS TDV8 conversion
My mechanic and I are currently in the process of "de-bricking" my 2011 Disco 4 with a snapped crank. We are achieving this by installing the 3.6 TDV8 from a RRS donor.
Everything is installed and ready to go! But the gearbox keeps going into limp because it isn't getting a signal from the Active Roll Control system. Its not getting a signal... because its not there!
Does anyone know how to electronically bypass this? Or am I stuck with pulling the body again to install the gear from the donor?
Post #617037 Mon Sep 06 2021 4:26am
Disco_Mikey
You won't get anywhere with Autologic, as I've already said, on your Fscebook post Thumbs Up
Post #617039 Mon Sep 06 2021 6:30am
LR3TDV8
Germany 2009 Range Rover Sport TDV8 HSE Lux Arctic Frost
Hey there! I just manage my TDV8 in the Discovery 3 running. All i want to change now are the softwarebits for the ARC / Dynamic Response, where you said it could be made easily on the 2.7.
What do i need to program? Just put the ARC to "not fitted"?
Would help a lot to get rid of those darn warning lights.
Thank you!
Post #617249 Mon Sep 13 2021 7:38pm
Hoppy65
England 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
anyone know were i can get this done in the midlands?
Post #621312 Wed Jan 26 2022 8:11pm
Great, another TDV8 being ruined. Rolling Eyes
Repair it properly. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #621344 Thu Jan 27 2022 11:31pm
